Kitchen Ranges Logo
Brian Ramsay Posted on Mar 23, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace oven light in whirlpool range - Whirlpool Kitchen Ranges
Bill Boyd
Level 3:
Top Expert:
  • Whirlpool Master 53,816 Answers
  • Posted on Mar 24, 2018
Bill Boyd
Whirlpool Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11932590
Points
172802
The glass cover screws out That can be difficult to do as greas burns in the thread and locks the thread
next the bulb is special pyrex glass so the bulb is only available from a service agent
5 Related Answers
Anonymous
  • 98 Answers
  • Posted on Sep 22, 2009
SOURCE: On a whirlpool electric kitchen range, the oven display is
HI. Sorry to say that the board may be bad. take the stove apart to get to it. there should be a fuse on the board. check it. The clock is there but on a curcit of it's on. But that dose mean the board is getting voltage. Hope it's the fuse.
Ken
Anonymous
  • 464 Answers
  • Posted on Nov 16, 2009
SOURCE: Whirlpool gas range model # GS475LEMS0; Oven light won't come on
If you are sure the bulb you purchased is ok, then I would check the door switch. It is #27 in the attached breakdown, and the part number is: 3196262. Hope this helps. 250
Anonymous
  • 1902 Answers
  • Posted on Jan 02, 2010
SOURCE: the oven doesn't work
unplg the system for 15 minutes then plug it back it. When you plug it back in make sure everything goes in straight. this is just trying to reset the system
Anonymous
  • 619 Answers
  • Posted on Feb 03, 2010
SOURCE: Whirlpool GR450LXLQO range while changing oven
You will have to replace the light socket. Part number is 3150505 at approx. 30.00. Hope this helps
Anonymous
  • 43501 Answers
  • Posted on Apr 10, 2010
SOURCE: Whirlpool self-cleaning electric range
You can find a replacement online by following this tip...
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Here is a tip about the replacement of the glass...
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
heatman101
Oven and broiler won't light
You may need to replace the part called the igniter module. It is what creates the spark that fires the gas.
Whirlpool electric range oven broiler not working
Hello. This is a common failure for this range. Replace part number
9762215, price varies but about $100 average.
Whirlpool electric stove not working
You will need to replace the thermal overload fuse in the back of the oven. Here is the part to order.
How to change oven light
Which model Whirlpool range do you have? For most Whirlpool ranges that I have used , the oven light is covered by a screw-on glass cover. When the oven is cool, unplug the range, open the door and turn the cover counter-clockwise (to the left). Then remove the 40W bulb (again counter-clockwise rotation). Replace the bulb with another 40W appliance bulb. Then replace the cover by turning it clockwise until it is tight. Do not over-tighten either the bulb or the cover. Then plug in the power cord for the range. (Unplugging the unit makes sure that you will not get shocked if anything goes wrong. Sometimes the bulb may break in the socket - in that case, use pliers to unscrew the base of the bulb before replacing it with a new bulb.)
Whirlpool has the manuals for most of their appliances on their support site: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
I hope this helps.
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
I blew the oven slector switch (part # 313061) on my Whirlpool RF3020 electric range/oven. The oVen light and heat does not work. The stove top lights still work but no or very little heat gets to the...
it could be a bad element but you would need to buy and replace the switch first to see if that fixes it I could not find it on the parts website but I will give you the number and you can call there 800 number and they can help you with the information you need, I am sure that if you replace the switch it should fix the oven. here's the site.
http://www.appliancepartspros.com/Appliance-Parts/?keyword=RF3020
I have an older whirlpool free-standing gas range and oven and the broiler works but the bake option does not, the oven doesn't get hot, any suggestions?
you may need to replace the bake ignitor. if it is glowing orange and not white, it isn't hot enough to light the bake. hope this helps
Oven problem with whirlpool 465
Replace your oven temperature sensor.
If that does not correct the entire problem report back.
You may also need to replace the electronic control for the oven.
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
