Https://support.hp.com/us-en/product/compaq-presario-cq62-400-notebook-pc-series/4346201/troubleshooting
See if any of the troubleshooting steps apply.
When does this error happen
1: boot black screens before the windows login screen.?
2: after boot and login, and disktop shows.?
3: does it only happen running apps. or running IE11.
4: only doing what? fill in the blank here _______?
but this PC is 10 years old
and needs a new RTC coin cell.
and you need to run HDD tests, if it dont boot.
terry's link above is correct one to real HP.
and very good.
but COMPAQ facts are hard to find today.
this old.
is this a BIOS password screen , showing system disabled, if yes that is only cured by direct help from HP ,they have a magic back door password
for all old PC by them (HP/compaq)
next time show a photo of errors, 10x more easy.
to answer....
here is the real HP answering this,
why not ask real HP for help, they made it>?
not fixya , we make zero here.
https://h30434.www3.hp.com/t5/Notebook-O...
I'm guessing bios password set,oops
The way i guessed that is tricky
that code you typed is not in the webosphere.
so is a code unique to your PC !
so is a BIOS password set then forgotten
enter the password 3 times wrong
you get a longer, code, and HP uses that to decode yours. ask HP.
SOURCE: non-system disk or disk error
Ththe comuter is presumably fdinding a disk at boot up.
Ensure there are no disk in the drives.
SOURCE: When I try to install
FIRST you go to your ANTI-VIRUS program , go to PROPERTIES , there your gonna see a window and where it says ANTI VIRUS enable or on , just click to disable it , i cant be more helpful cause I dont have the brand of your anti virus software , hope this helps AJ
SOURCE: '03 compaq presario x1000
On a desktop pc u hear continuos beeping it's something to do with da ram so try replacing the ram or reseat the ram for help go to compaq.com
SOURCE: System unit error in pentium 3 compaq presario
304 error reffers to keyboard error. Verify if your keyborad is properly plugged in, also verify if it's working (pressing Num Lock will turn on the led, pressing again will turn off).
If you plugged in an USB keyboard it won't work, it is necessary to be present an PS/2 keyboard.
Testimonial: "that i know i remove keyboard error but wat about system unit error.. nyways thanx"
SOURCE: Compaq Presario C700 sled off bed. Getting error
IF YOU ARE ABLE TO PULL OUT YOUR HARD DISK, THEN RESET IT AGAIN IN THE SLOT, TO BE SURE IT IS BEING PLACED TO ITS RIGHT POSITION, THEN ON YOUR SYSTEM AGAIN, IF IT WORKS, FINE IF NOT...COULD BE THE CONNECTOR TO HARD DISK IS CRACKED WHILE IT WAS DROPPED..
