Have a smart tv and when i press netflix this comes up
Make sure that you have the correct password in for your smart TVs Wi-Fi or connect in ethernet wire to the router. They may have to refresh the router check another computer or your phone to see if the Wi-Fi is working
SOURCE: vizio vt420m invalid format when trying to view netflix
The TV can't read the format that the data is in, it is a kind of code, your tv can decipher it.
If there is no sound comes with on-air programs, and there is only picture, check the settings. That is, if the transmission system at your country is PAL, and you have set the system at your TV to NTSC or SECAM, there will be no sound. Check it. Refer its user manual for details. It will be best to set this option [color system option] to Auto. If so, the TV will adjust the system by itself.
Gopakumar Gopalan Google
Do a hard reset to this set and check. If it do not help you, contact the authorized service center for RCA. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
I Could help you more if I knew the Model Number of your Samsung Smart TV.
But to be short, try checking the audio menu of your television, and turning off internal speakers and switching the audio to external output. The smart TV should detect the kind of audio system you have connected to it.
SOURCE: How do we access Netflix? On Sony smart TV. Paid for Netflix
If your TV does not have Netflix pre-installed you can (only on some TV's) install the app from the internet. If you cannot install Netflix on the TV then you can use something like the Amazon Fire Stick plugged into one of the HDMI ports to watch internet based content such as Netflix.
