Hi!
It's probably a loose connection between CCD and main board. It's a well know problem with these cameras. If you want to fix it yourself, take off the front cover, then back cover, remove the frame on which the LCD is on, be very careful with the keyboard cable. I suggest you don't disconnect it! Check the CCD connection to the board.
I work in a Kodak service center.
Hope this helps!
Tom
The above solution worked for me, with the same problem! Opened up the whole camera, including the cover that the LCD is on, and saw that one piece was sticking up a bit. I pushed this down until it seemed to click in a bit, and lo and behold, the purple and pink went away.
THANK YOU!! :)
