If m3 phase the possibility is for the motor to run backward depending on lead connections. If you replace motor wire it up and press contractor and close power contacts let go and observe motor rotation. If needed to change rotation switch lead 1 and 3. When I installed pumps I removed coupling to run motor..
I know about phase rotation I was wanting some info on the Hobart h67 wether or not the pump is 3 phase or single I’m having trouble finding operating manual
Is It possible to measure the incoming power? I don;t know where you are but Us the most common for such items is 208-230 3 phase I20 from leg t ground. phase to phase 208 -203. I worked with 480 3 phase but the logic applies. If you can get to breaker it should be labeled . Another is 3 phase has 3 pairs of contacts, the single phase has 1 or 2 . How big is the motor? Does the motor have name plate. Your right that will be a hard manual to find. maybe on the country.
SOURCE: Need to convert 3 phase Hobart dishwasher to single phase
It will not be inexpensive to convert your dishmachine over to three phase. With everything that you will need to replace, depending on the model if converyor or not it may run close to what it costs to have 3phase run to the building that you plan to move into.
SOURCE: electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
SOURCE: Need to change oven from 440 3 phase to 220 single
It can be done with a transformer, 480/ 240 single phase transformer to get the lower voltage. Then the oven will require some wiring changes to get all the elements and controls connected to two hot wires instead of three. The transformed will be sized to the wattage rating of the oven. This is a only basic description of what needs to take place.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: hobart model 5801 meat saw conversion from 3 phase
No, you need a new motor or a converter, but in the case of one saw, it wouldn't be worth the conversion. Just find an old single phase motor that will fit height wise and you should be all set. The speed is the same, the direction can be switched and the HP should not matter much, 1/2 , 1, depends on what you find out there. They all should cut wood no problem. Hope this helps.
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
