Question about Watches
How to set date one a wr30m watch - Watches
    Problem Solver:
  • 5 Answers
I made $64,000 so far this year working online and I'm a full time student. I'm using an online business opportunity I heard about and I've made such great money. It's really user friendly and I'm just so happy that I found out about it. Here's what I've been doing.............https://bit.ly/2qPkxOO
Posted on Nov 12, 2019
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Setting Time and Date on a Timex WR30M
1) Press and hold mode for about 2 seconds and then release. You will now be in the alarm edit mode.
2) Press mode once more and now you are in time edit mode.
3) Use the stop button to select what to edit, i.e. hour minute, etc.
4) Use the reset button to make the changes once you have selected the hour/minute, etc. that you want to change.
5) Press
Posted on Nov 18, 2008
Anonymous
  • 98 Answers
SOURCE: Bijoux Terner
If you are having trouble setting the watch there could be an issue with the movement itself! I suggest taking to a watch repair business and having them take a look. If the movement is bad it shouldnt cost too terribly much to replace it.
Posted on Jan 09, 2010
Kevin Penn
  • 1139 Answers
SOURCE: I have a WR30M watch
Follow these steps to adjust the time :
Step 1. Press and hold MODE for 2 seconds and then release. The watch will be in alarm mode.
Step 2. Press mode again to enter time mode adjust.
Step 3. Press the stop button to cycle through what you want to adjust.
Step 4. Press the reset button to adjust the actual item.
Step 5. Press MODE to exit time setting mode.
Hope this helps
Posted on Nov 24, 2010
My Watch is showing military time but i want it to show in the 12 hr clock
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
http://www.fixya.com/support/t6812987-change_timex_wr30m_from_24_hour_12
How do change my timex wr30m from 24 hour to 12 hour display
Mar 21, 2018 | The Watches
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
Dec 13, 2017 | Timex Watches
Pasnew watch Model wr30m set time
Try Googling (Pasnew)(wr30m)(manual) without parens to get instructions.
Nov 09, 2017 | Watches
How to set the time on a wr30m watch
google how to set time on a wr30m watch
Sep 10, 2016 | The Watches
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 | Watches
How to change the date on a Mingrui WR30m watch and also the day setting unless these are corordinated?
Keep on clicking on mode until it comes up with the seconds flashing. Then click on reset 5 times until the day is flashing. Then click on start until the day changes to the day you want! :D It worked for me
Sep 25, 2011 | Watches
How do I change the day on my Timex WR30M Easyreader Indiglo watch. I can change the date, but not the day of the week. Help....
When you bought the watch, did you find a little manual in the packaging? The manual has all the info.
Dec 19, 2010 | Timex 27191 Wristwatch
How do i change my timex wr30m from 24 hour to 12 hour display
Hi cbrichw,
Hope it helps.
Thank you for using FixYa.
Nov 13, 2010 | Timex 1440 Nylon watch
Watches Logo
1,653 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
