I have 3rd party toner cartridges installed against the firmware's suggestions, but I performed the correct firmware upgrade otherwise according to the instructions. All the buttons are non-functional, hard power reset reboots the printer and the same lights start flashing. I'm unable to find the printer on my network anymore either wireless. I've tried rebooting the printer and holding down both the power and reset buttons, and just the reset button with no luck. I need a factory reset option here.
SOURCE: Dell 1700 laser printer has Low toner and error lights flashing
Leave the printer on. Open the front and hold down the cancel button until all the lights are flashing in sequence. Close the front while still holding the cancel with the lights flashing and then release the cancel button. This should reset it.
Thanks
SOURCE: constent reboot - flashing Access Powered
There is a soft/warm reset which bypassed the loop without losing your data. press the up key and reinstall your battery. do not let go until the palm screen fully loads. when fully reloaded let go. sounds a little confusing but the palm website has step by step instructions.
SOURCE: My Canon Pixus 50i printer
I have something to ask you, Can you tell me where I can get drivers for the printer Pixus 50i.
SOURCE: Current Problem on Printer """E5"""
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
SOURCE: Can't get past step 2 of the Canon i550 waste tank counter reset.
Hello you can try
Problem for Canon BubbleJet i560 InkJet
The waste ink is in the inside of your printer you need to get at it to clean out,
It may be all screwed down so you need to open all up or get a shop to do it for you.
It not an easy job but maybe you are handy with a screwdriver, it can be messy job.
But after this, you will have to reset the waist ink counter or it will still not work,
But but but but you can always try this to reset it first and clean it out again some time.
Canon Reset waste ink counter
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
For any query related to Samsung printer you can call on Toll Free no-1-866-877-0191.
