SOURCE: Kohler 1-piece flush valve seal replacement.
That is a tricky one. Tighten the tabs, twist into place, then tighten a bit more. They are a pain in the a$$, but with patience you will get it done. Good luck
SOURCE: I just installed a Kohler Wellworth toilet. WhenI ...
As long as this toilet is NOT a pressure assist toilet. Then it probably has a water saver flapper that you can replace with a non water saver flapper. This will allow it to flush more. Be advised you may have to adjust the water level after the change to prevent it from double flushing. Hope this helps.
SOURCE: Front Strut Top Cover not flush protruding from
That is fine as long as it is not loose and making noise when you are driving. In some cases this is a sign that your strut bearing rubber bushing assembly are wearing out and need replacement.
SOURCE: I have to replace the gasket which the flush valve
The top of the pipe above the flush valve is threaded if you unscrew this you will be able to remove the flush valve and replace the gasket. I am assuming we are talking about the same here is a link that has all the parts:
http://www.plumbingsupply.com/kohlertoiletparts-santarosa.html
