Bosch dishwasher model SHX3AR75UC/22 is intermittently not completing the cycle. When it fails to complete the cycle, it also does not drain the water, leaving it in the bottom of the tub. The dishwasher seems to "think" it has completed the cycle and does not need to be reset to start another cycle. The soap dispenser does not open when the machine fails. After this started, the machine continued to work on the "Express Wash" cycle, but now does not work there, either. possible transformer overheating or bad board
I have the identical issue in a similar model. What was the resolution? Thanks!
Check filter on the pump if chocked
It maybe something as simple as the door opening during the cycle - thus pausing the machine - this can happen when the machines with plastic tubs get hot - the top of the machine flexs a bit and the latch disengages and the machine stops. Next time it does it just try to push the door closed and hit start and see if it picks up where it left off. A stiffener is needed to repair the fault - but we have fixed with shims in a pinch - between the counter top and the dishwasher to minimize the flex
SOURCE: Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
SOURCE: Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
SOURCE: BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
I ended-up replacing the main board. It's fairly easy--remove the interior of the door and swap out the board, IIRC.
