SOURCE: i plug in my casio
If you lucky, the power jack may be at fault since it switches from external to internal battery, but most likely the internal supply is what's damaged... IC regulator possibly. A quick voltage check with a volt meter at the power leads on the main board will verify battery or xfmr supply voltage, if voltage is present then look in close proximity for an IC regulator and check for an output.
SOURCE: how to do a master reset a casio ctk 496
According to the manual for the 496, "All keyboard settings are returned to their initial defaults whenever keyboard power is turned back on after being turned off by operation of the Power/Mode switch or Auto Power Off.
SOURCE: Casio CTK 810 with Windows 7
You need a midi to usb interface, otherwise it is quite simple. I personally have an M-Audio interface that plugs into my midi out and plugs into your usb port on your computer. Once done, you can create a profile in Reason for your CTK. Windows 7 will notice the M-Audio device and then you will be able to use midi. You may have to install a specific driver for the particular M-AUdio device (or another midi to usb interface) but that is simple. You do not have to worry about a driver for the keyboard.
In my experience, M-Audio makes about the best midi/usb interface, and they come in all popular configurations. I use a very small 1-to-1 interface, though there are multi port interfaces one can buy. I purchased mine on eBay, though you can find them at Guitar Center if you have one in your City, or alternately Musiciansfriend.com web site. Many online stores sell them though. You amy want to use Amazon or a price comparison web site to find your best deal.
Thank you for using FixYa, and good luck.
SOURCE: no display light on my casio ctk 496 every thing else works
Sorry, but many of the low end keyboards do NOT have backlights. This is especially true of those that have the capability of running off batteries like the CTK-496.
The display in this is a reflectance type that needs ambient lighting to view.
SOURCE: Casio CTK 800 spare key
I can think of two places. eBay search for
Casio LIGHTED KEY KEYBOARD
or call casio and explain to them what happened and see if they can help :)
Steven.
