SOURCE: how add developer to sharp ar-208d
Set-up for this copier sure isn't well-documented. We just got ours working today, by following the instructions here: https://www.businessneedz.com/Manuals/ar168s_setup.pdf (yes, it lists a different model number, but the instructions worked, and were linked from the ar-208d product page from the supplier)
SOURCE: In sharp 5316-toner is not transferring from toner cartridge to developer unit , copy is light .
Most likely need to replace the developer
SOURCE: Developer power cannot put over the Magnet roller correctly. some gabe on the magnet roller
It sounds like either you contaminated the mag roller or there is a loose connection that causes the mag roller to charge. You might have to just order a new developing unit.
Sir, what color has the problem? I don't understand you question? Are you using OEM parts. Have you had qualified Konica Minolta technician look at it?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Testimonial: "In this case is magenta, but also happens in more colors.New development unit, after 3000 copies , leaking developer. I would like to make a general Rist so I get a machine with no data as if it were a new machine out from the production line. And then do Update software. I'd love to know if there is another solution to the problem of leaking developer. Thank you"
