Cars & Trucks Logo
Mardie Griffin Posted on Mar 13, 2018
Belt slipped off the tension pulley on my 92 ford E350 jamboree motorhome
How do i get to it and put it back on
5 Related Answers
Anonymous
  • Posted on Mar 31, 2009
SOURCE: Belt Tensioner located on 2000 ford Escort zx2
On the right side of the pulleys, there should be 3 top, middle, and bottom. The middle, smaller one, is the tensioner.
Anonymous
  • 962 Answers
  • Posted on Apr 05, 2009
SOURCE: serpentine belt slips off idler pulley
The A/C pully is supposed to spin freely until the AC is activated to run.. The cranshaft pully does not. Replace the tensioner pully. The belt has to fit in between the grooves on the pullys.
Anonymous
  • 15935 Answers
  • Posted on Apr 26, 2009
SOURCE: Can't get A/C belt around pulleys on my 01 Chevy Tracker 2.5 V6
Removal & Installation
1.6L Engine
A/C Compressor Belt
  1. Disconnect the negative battery cable.
  2. Loosen the A/C compressor mounting bolts.
  3. Pivot the A/C compressor towards the engine in order to relieve the tension on the belt.
  4. Remove the A/C compressor drive belt from the pulleys.
To install:
  1. Properly route and install the A/C compressor drive belt on the A/C compressor, the power steering (if equipped), and the crankshaft pulleys.
  2. Adjust the A/C compressor drive belt to obtain 6-9 mm (0.24-0.35 in) deflection.
  3. Tighten the A/C compressor mounting bolts to 13-20 f t. lbs. (18-28 Nm).
  4. Connect the negative battery cable.
Alternator Belt
  2. Remove the power steering pump and the A/C compressor drive belt.
  3. Loosen the generator mounting bolts.
  4. Pivot the generator towards the engine and remove the accessory drive belt.
To install:
  1. Properly route and install the generator drive belt on the pulleys.
  2. Adjust the alternator drive belt to obtain 6-8 mm (0.24-0.32 in) deflection for a used belt or 5-6 mm (0.20-0.24 in) deflection for a new belt.
  3. Tighten the generator mounting bolts to 17 ft. lbs. (23 Nm).
  4. Install the power steering and the A/C compressor drive belt.
  5. Connect the negative battery cable.
Power Steering Pump Belt
  2. Loosen the power steering pump mounting bolts.
  3. Pivot the power steering pump towards the engine in order to relieve the tension on the belt.
  4. Remove the power steering pump drive belt from the pulleys.
To install:
  1. Properly route and install the power steering pump drive belt on the power steering pump and the crankshaft pulleys.
  2. Adjust the power steering pump drive belt to obtain 6-9 mm (0.24-0.35 in) deflection.
  3. Tighten the power steering pump mounting bolts to 22 ft. lbs. (30 Nm).
Anonymous
  • 79 Answers
  • Posted on Apr 27, 2009
SOURCE: tension pulley for the Serpetine belt
The tensioner is the 3 1/2" pulley located between power steering pump and alternator down about 5" on front of engine. Does it have air conditioning?
If you need the diagram please post your email address and I will email it to you as I do not know how to post pictures on this.
Anonymous
  • 667 Answers
  • Posted on Sep 22, 2009
SOURCE: 2002 Ford Escort ZX2 serpinten belt routing & tensioner pulley
go to www.gates.com on the lower right hand side under popular topics, click on timing belts, then on the left hand side click Parts Locator and Interchange, enter your cars info and the first page that comes up will show you a camera icon for a pic of how your belt is routed. The tensioner pulley is the one mounted on a silver arm, usually at the top. Hope this helps let me know.
What is the 1978 Ford Jamboree motor home e350 ecoline belt replacement diagram?
Cheapest first,try water pump for rusty traces,
does it go away when warm,
does your battery drain? Get back to me please.
How many quartz of oil does a 1995 E350 jamboree motorhome take?
Depending on what size oilpan you have, it's between 5-7 qts. Put in 5, start it. Check, and add as needed.
How do i put the serpentine belt back on my 2001
it has a spring loaded tensioner pulley. some use a bolt that you put a wrench on and pry back to release tension to slip belt on. others just use a ratchet drive (3/8) . #5 is the tensioner. going to need to get belt in behind the wrench or you wont be able to slip belt on bc wrench will be in the way
Serpentine belt 1990 ford f150
Find the spring loaded Tensioner pulley and use a wrench on the nut in the center of the pulley to pull the pulley away from the belt. Once you have released enough tension, you can slip the belt off of one of the other pulleys and gently release the Tensioner pulley. slip the belt off the rest of the pulleys and put the new belt in the same way the old one came out, pulling the tensioner pulley out and slipping the belt back under it, before gently releasing. Make a note beforehand of how the belt is installed to be sure you get it back in correctly. The grooves in the belt should go against the grooved pulleys and the flat side of the belt should go against the flat pulleys. This diagram may be helpful.
2answers
What makes a belt squeak?
Belts squeak for the same reason tires do when they spin. They are slipping. Something isn't turning as fast as the belt wants it to. On ford it's usually ether the idler sprocket or the tensioner. If you remove the belt and try spinning all of the pulleys by hand.( note the crank wont spin freely) you will usually be able to tell witch ones slipping.
Hey there. I am replacing Problem with the 1997 Taurus hey there. I am replacing the serpentine belt on my 1997 Ford Taurus. The idle pulley bearings were shot, so the old belt actually slipped off. I am...
make sure the tensioner is tight,it has a spring in it to move clockwise,do not leave any bolt loose,make sure you are routing the belt where the tension holds the belt on,not other way.
Tim
2answers
THE BATTERY LIGHT CCAME ON AND IT WAS DIFFICULT TO STEER POWER STEERING FLUID IS THERE BELT CANE UNRAVELED NO HOSES APPEAR TO BE LEAKING OR BROKE. HOW DO I PUT THE BELT BACK ON
First check all pulleys for wobble or looseness. If all pulleys are OK, use the below diagram to put the belt on all pulleys except alternator. Put a wrench on tensioner pulley and pull down until the belt will slip onto the alternator pulley. Check that belt is still on all pulleys before starting. If belt comes off again, one of the components is failing (usually an idler, tensioner or water pump wobbling).
2helpful
I need to replace the pulley that puts tension on the belt of a 93 ford f 150 with a 351 engine
Hi:
The basic process to change that pulley is to first loosen and remove the serpentine belt. Make a diagram on paper of the belt path, if there isn't one under the hood on a decal.This is done by putting either a wrench or ratchet on the tensioner, and rotating it away from the direction that it applies pressure to the belt. There is either a square hole to put a ratchet in, or a hex head to attach a wrench. Once you get the belt slipped back, examine the belt to see if it needs replaced. The tensioner assembly is held to the engine with a couple bolts, and can now be removed and replaced. Reinstall the new or old belt, and the last step is to rotate the new tensioner back and slip the last section of belt under it.
1993 ford probe belt slipped off how to tension
your car may have information around in engine comparment is a diagrama of the belt how to put it back on. you have to have a tensioner pulley witch you gatta use a tool to depresset the tension so the belt fit right
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
