Question about Canon Office Equipment & Supplies
Solution for canon ir2520 /error code e000002
    Master:
  • Canon Master
  • 906 Answers
Hi. you need to enter in service mode
with the machine turned on, in the control panel do the next key secuence:
press adittional function
press 2
press 8
press again adittional function.
service mode should appear in the screen: (#SSW)
tap in the arrow ? or ? and search for CLEAR
press OK once, with arrows search for ENGINE and press Ok once, with arrows search for ERRCLR and press OK once more.
turn off the machine from the main switch for about a minute and restart it. try to make some copies, if problem persist there is a malfunction in the fixing unit, get technical support.
if this answer was helpfull , please rate it. thanks
Posted on Apr 16, 2018
  • VICTORIA CHRISPINE
    VICTORIA CHRISPINE Jan 19, 2019
    Thank you so much.... your answer was very helpful
  • Anonymous Aug 29, 2019
    If you are facing any kind of error while using the cannon camera then you must see what kind of problem you are facing and Read Full Article to getting writing tips and more style to make effective look. If your cannon is not saving the pictures that you have clicked then you must see the setting or if anything else is then you should check it.
You clean sud theromostor dirty
Posted on Dec 04, 2019
6ya staff
SOURCE:
SOURCE: Error Code E000002-0000
What does an error code E000002- canon 2545i
mean
Posted on Jan 03, 2013
sonu_goyal
SOURCE: Canon Image runner 3200 error code E000002-0102
press *28*
<functions>
press "clear"
"error"
<Ok>
then off the main unit and on it
Posted on Dec 17, 2009
Anonymous
SOURCE: CANON IR5000 ERROR CODE E000002-00000
NEED HELP WITH ERROR CODE E000246-0005
Posted on Dec 21, 2009
canontech
Canon tech CROATIA
  • 1219 Answers
SOURCE: error code E000002-0000
Get in the service mode *28* and there under function, clear, err.
If not replace the fixing film unit
Posted on Mar 03, 2010
hamzaskilltd
amir hamza
  • 318 Answers
SOURCE: error code e000002-0000 canon ir 3300
fixing assembly low temperature
Posted on Jun 26, 2010
HOW TO CLEAR ERROR CODE E000002-0000 IN CANNON IR3300/2200
http://www.copytechnet.com/forums/canon/24451-canon-ir3300-error-e000002-0000-a.html
Thread Canon IR3300 Error E000002 0000
Quoting:
wilson Technician Join Date Feb 2009 Location PASIR MAS , KELANTAN
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
Jul 02, 2018 | Cannon Office Equipment & Supplies
Canon 2525i image runner bringing error E000002. What could be the problem with the machine
Error E000002-0000 on B/W printer. That is the error code for a power supply failure or the printer not receiving enough power to heat the fusilier to print. This can be due to an power outage or not enough electricity flowing into the machine. ... Hit "additional functions" key on the printer's keypad. Canon ir 2520 2525 2530 error e000002 How to solve
Jun 18, 2018 | Canon Office Equipment & Supplies
Canon ir2520 error E000002 where is the problem ?
problem with fuser.Go to the following to clear error:CLEAR<ENGIN<ERRCLR;and than turn off the machine and back ON.Check the connectors;replace the main thermistor;replace the fixing film;replace fix.assy. ; replace DC controller
Feb 25, 2015 | Canon Office Equipment & Supplies
Error code E000002 in Canon IR2520
Dear
it indicates fixing unit temp could not raised to predetermined value. The following steps may be taken to clear the error.
CLEAR>ENGIN>ERRLR; and then turn OFF and then ON the power.
2.Check connection of the Connectors (Thermistor Connector and AC Connector).
3.Replace the Fixing Assembly.
4.Replace the DC_CON PCB.
Thanks
Feb 13, 2015 | Canon Office Equipment & Supplies
How to solve error code of E000002-0000
The problem is in temperature of a fixing film.Try to clean the heater,put on the grease...If ther's still a problem,replace the heater
Sep 23, 2014 | Canon Ir 3300 Black & White Copier
How i fixes error code e000002 i change new fuesr unite but the error code is not remove pleas help how to solve?
http://www.copytechnet.com/forums/canon/5317-canon-ir-2200-error-code-e000002-0000-a.html
Aug 10, 2014 | Canon Ir 2525 Copier new
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
2,437 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
