Easy to find online
https://www.google.com/search?q=battery+for+video+camera+JVC+GR-DVX-507EK
SOURCE: Condensation, operation paused, JVC Video Camera model GR-D70AS
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
SOURCE: I NEED TO TRANSFER VIDEO
first option you may use is the latest version or iMovies, you may download that from Apple's website. you can just save your video files to the Mac, then get it played / converted using the new version of iMovies.
hope this helps, should you have other questions just let me know.
SOURCE: GR-D250U manuel
You can get it here:
http://camera.manualsonline.com/ex/thread/view/idThread/124172
Please note that you will have to register with them for free to download the manual.
Hope that helped!
Please assign a Fixya rating if this solution helped you!
SOURCE: Hi, I have a JVC
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. As you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
