SOURCE: Programming the 00-749825 Control Board on a Hobart AM14C
That board comes with directions. if not go to hobart and have them copy you one out of a new boards box
SOURCE: For a HOBART AM14C I have a faulty ccc (294551B).
HI,
ACCORDING TO THE SPECS IVE SEEN ON BOTH BOARDS YOU ARE CORRECT THEY ARE NOT THE SAME BOARDS AND THEY DON'T CROSS REFERENCE TO EACH OTHER EITHER I WOULD RETURN THE BOARD TO GET THE CORRECT ONE.
HOPE THIS HELPS GOOD LUCK.
SOURCE: Need to convert 3 phase Hobart dishwasher to single phase
It will not be inexpensive to convert your dishmachine over to three phase. With everything that you will need to replace, depending on the model if converyor or not it may run close to what it costs to have 3phase run to the building that you plan to move into.
SOURCE: Hobart AM-14 water temperature not maintained
Hobart AM-14 will wash and rinse in manual, but not in automatic
SOURCE: can I change the 3 phase to a single phase?
Not practical. You would have to change the pump motor to single phase, you'd have to chage the heating element most likely depending on what size is in it now. Also does it require an auxiliary water heater? it's probably 3 phase also. Changing phases is not like changing voltages.
