SOURCE: TV has panaramic view/ 3D view.
Symptoms shows its problem of failure of convergence out ICs on D board.
Find IC8001 and IC8002 on D board and replace them as per following part number...
8-749-019-08 STK392-560
You also need to check following pico fuse PS8001 to PS8006 (6 fuses) as few can be blown off and requires replacement.
You should do above said repair if you have knowledge of electronics, have experience of big TV repair, have necessary tools and know that electric shock risk is involve in TV repair.
Let me know if you need further help.
Good luck.
SOURCE: projectors are out of alignment all colors are working looks 3d
You are going to have to replace your STK ICs convergence ics STK392-560 or 570 Call Electronix Parts 1-800-223-3205 Use STK number on ICs.you will also need some heat sink silicon to put on back of new ICs.
SOURCE: Display looks like you need 3D glasses to view.
Sounds like a convergence problem.
Especially since you said that the screen(picture)wasn`t linear anymore.
If the magic/touch focus function doesn`t clear the problem then your convergence modules may be faulty.
They are used to align the three tubes (red/green/blue) deflection.
If you feel handy with a soldering iron i could assist you in replacing them, otherwise you might need the help of a local repair tech.
Hope this help. Good luck
Testimonial: "Thanks for the advice. I'll give that a try. Appreciate your fast response!!"
SOURCE: Black screen in 3d view
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
CONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
SOURCE: Hi, Iam trying to set up a 3d system. Iam using an
Welcome to Fixya.
Acer h5360 1280x720 supports Bluray 3D see Documentation. However the Intel 945 Express Chipset Display dont have Pixel Shader 3.0 recommended for optimized visual performance. And like other HD movies you need to use a high definition cables such as HDMI or Component Cables.
Thanks for using Fixya.
