SOURCE: waste toner container on canon imagerunner 330s
It is located below like a small box/ press beside the box to release /
www.justmanuals.com
SOURCE: canon imagerunner c2880 (GPR-23)- Waste receptacle
i dont know about any counter to reset,the message is displayed when there is waste toner in the sensor window of the waste toner bottle.That window can also be cleaned.
SOURCE: I have a Canon ImageRunner C3170U/C3170I
When you open the front cover,there is a transperant bottle with waste toner remove the bottle and remove the waste toner from the bottle.There is aslso a small clear transperant plastic holder that detect the level of the waste toner.Use a no2 star skrewdriver and remove it.Clean it and put it back.And reinstall the waste toner.
SOURCE: How do i replace the waste toner container on a
The waste toner bottle is hidden behind the front cover of the machine. Just under where you fit the toner cartridge.
If you are competant with a screwdriver, remove this cover and you will find the Waste container. The screws for the cover are hidden behind a rubber bung.
SOURCE: canon 2220i imagerunner how do you empty the waste
Hello autumn,
Lets start with a reference,which will be standing in front of the copier. Ok,using this reference the waste toner bottle is located on the left side of the copier at the the lowest point of the left side almost at the back of the copier. If you have a stapler/finsher you will need to un-dock it from the copier and slide it away as far as possible, It need not be removed. Now you will have located a cover with one screw. Remove the screw and remove the cover.You now see the bottle.It has a handle so slide it out being careful not to spill it. You can of course pour the waste toner into a strong plastic bag,taking whatever cautions you see fit as you have one hell of a potential mess if not handled carefully.Once the bottle is empty, please notice the neck of the bottle. The way the copier "knows" the bottle is full is by sending a beem of infrared light thru the neck of the bottle. When the waste toner fills the bottle to the neck and blocks the beam of light the copier knows the bottle is full. My point is make sure you clean the neck of the waste toner bottle (if you look closely you will see the "windows" the light travels thru) by using a Q Tip or tissue. If the "windows" are clouded the copier will think the bottle is still full even though the bottle is empty. Does that make sense? In other words you could put a brand new waste toner bottle in the copier with black tape around the neck of the bottle and the copier would say the bottle is full.So now that its empty, and the neck is clean, replace the bottle and the cover.Turn off the "main power switch" located on the right side towards the rear of the copier.Wait a sec, turn it back on and you should be in good shape.Take care and let "FIXYA " know if I helped please. SPINAL
Testimonial: "IT WORKED!!!!! thank you so much you saved the day!!!!!!!!!!"
