Computers & Internet Logo
a
aldrin diwa Posted on Mar 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is gigabyte ga g41 combo is compatible with gtx 550ti
ronan cainglet
Level 2:
Habit-Forming:
New Friend:
  • Expert 55 Answers
  • Posted on May 30, 2018
ronan cainglet
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
55
Questions
0
Helped
13212
Points
160
5 Related Answers
cpenzes
DEKR
  • 1102 Answers
  • Posted on Feb 13, 2009
SOURCE: Compatable gigabyte ga 81915pm motherboard
you may not have to format
you should be okay
are you sure power supply is not going
remove cd drive and boot see if you can get to safemode
Are you sure you have'nt had pc opened and maybe loosened a memory
I still don't think it's the motherboard.I would go more for a memory or power supply problem
let me know
Anonymous
  • 138 Answers
  • Posted on Sep 27, 2009
SOURCE: gigabyte ga-8i915pm
You can download the manual here
Anonymous
  • 2653 Answers
  • Posted on Aug 14, 2010
SOURCE: driver GIGABYTE GA-60X REV;1.0...
Everything you need is HERE.
Anonymous
  • 32281 Answers
  • Posted on Mar 22, 2011
SOURCE: Gigabyte GA-8I865GME-775-RH Motherboard core 2
You can download the device drivers from Gigabyte WEBsupport site, select your model motherboard to download :-http://www.gigabyte.com/support-downloads/support-downloads.aspx
Anonymous
  • Posted on Jun 09, 2011
SOURCE: in my gigabyte g41-combo mother board sound driver
i dont at all think that it is a problem. If windows 7 is not detecting your built-in via 1708s sound card then try installing the latest drivers from the gigabyte website or the via official website. If that doesn't work then try installing an add-on sound card that you can buy from anywhere.
2helpful
Is it safe running PCI-Express 3.0 card( Geforce GTX 650ti Boost) on Gigabyte GA-G41MT-S2PT( PCI-E 1.1 ), or should i go with Geforce gtx 560ti (PCI-E 2.0). Help please...
All cards a backwards compatible. So a PCI-E 3.0 will work in a PCI-E 1.0 Slot. You just can use a PCI-E 1.0 card in a PCI-E 3.0 Slot. To clarify you can safely go with the GTX 650ti. Happy gaming!!
Shutting down for no reason
Try testing with other power supply and see if it gives you the same results.
Does GA-G41M-ES2L Motherboard support asus gtx 650 graphic crad?
http://www.gigabyte.com/products/product-page.aspx?pid=3500#ov
Specification:
Motherboard chipset;
Intel G41 Northbridge; Intel ICH7 Southbridge,
(The Intel ICH7 is also Intel part number 82801GB)
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
(CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short)
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
G41, scroll down towards the bottom of the chart.
(Past P45)
Introduced in the last quarter of 2009
http://en.wikipedia.org/wiki/PCI_Express#PCI_Express_2.0
The PCI Express 2.0 technology came out January 15, 2007
Means your PCI-Express x16 slot is based on the PCI Express 2.0 technology
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121725
The Asus GTX650 graphics card, (No matter which version), is based on the PCI Express 3.0 technology
PCI Express 3.0 technology is Backward Compatible, with PCI Express 2.0 technology,
http://en.wikipedia.org/wiki/PCI_Express#PCI_Express_3.0
"PCI Express 3.0 Base specification revision 3.0 was made available in November 2010, after multiple delays. In August 2007, PCI-SIG announced that PCI Express 3.0 would carry a bit rate of
8 GigaTransfers per Second, (8GT/s), and that it would be backward compatible with existing PCIe implementations."
PCIe =PCI Express
So yes it will work, AND will work at FULL capacity.
Also your motherboard chipset (Northbridge), will support Intel processors that utilize an LGA 775 processor socket, AND up to an Intel Core2 Quad CPU. (Processor)
DOES TAKE SOME POWER, though!
You need a Power Supply that will not only deliver the necessary Wattage, for the computer system; but also need Up To an additional 150 Watts JUST for the graphics card itself.
Know what happens when you try to under power, a powerful graphics card?
Things BURN,
Or
The computer doesn't work
A) The contact pins in the PCI-Express x16 slot, will burn
B) The gold plated contact pins on the bottom, of the graphics card will burn
C) The graphics card requires more power, than the PCI-Express x16 slot can deliver.
A PCI-Express x16 slot can only deliver Up To 75 Watts.
A 6-pin PCI Express power cable is required.
This power cable can deliver Up To 75 Watts.
If there isn't enough power the contact pins, in the 6-pin PCI Express power cable will burn.
So will the contact pins for the power cable, on the graphics card.
The motherboard by itself requires 120 to 150 Watts.
Depending on Processor, Up To 130 Watts.
For each stick of Ram Memory add 25 Watts
25 to 30 for each Optical Drive. (CD/DVD drive)
2 to 3 Watts for each fan; to include the Processor fan, and computer case fans.
Now add 150 Watts for the graphics card.........
For additional questions please post in a Comment
Regards,
joecoolvette
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Southbridge_9xx_and_3.2F4_Series_chipsets
1helpful
Gigabyte GA-G41M-ES2H LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=3468#ov
A new hdmi connector, can be ordered by a gigabyte dealer.
But changing the connector, is not a do it your self job.
I suggest you to buy a graphic card, to add on the mainboard in the
1 x PCI Express x16 (orange slot) for better performance.
A new graphic card, does also have the hdmi connector
This will be the cheapest way to repair it.
Good luck
Can Gigabyte GA-G41M Motherboard will support pentium d 925 processor
Hi there
Without detailed info about which model of G41 board you have it is impossible to give a definitive answer as looking at the Gigabyte website, some do and some don't. If you go to this page,
http://www.gigabyte.com/search/search.aspx?kw=GA-G41M#pr-1
you will find a list of G41 boards. If you click on your board you will go to a page with several tabs, one of which is "support & downloads". If you click on this you will find a red label saying "CPU support list". If you click on this you will get a long list of the PUs supported by that particular mobo.
Good hunting
Problems with gigabyte fx990ud5 when using sli
do you have degauss option ? it should correct it. That pink tint will be always there but during gaming the colors are enhanced , thus pink will be visible
Do GeForce GTX 550 Ti fit with igabyte GA-MA74GM-S2 (rev. 4.4, motherboard, micro ATX, AMD 740G) specs mobo
This GeForec graphics card connects to a PCI-Eexpress 2.0 x16
and this Gigabyte has a PCI-Express 16 expansion slot which is compatible with the GeForce graphics card.
You may need to disable the on-board graphics card in the BIOS.
Will GeForce GTX 550 Ti fit with Gigabyte GA-MA74GM-S2 mobo
This GeForce graphics card connects to a PCI-Eexpress 2.0 x16
Newly bought Gigabyte G41 Combo Motherboard shuts down automatically for no reason.No heating or ram or smps issue.
If you have a problem regarding cpu then follow this steps:
  1. Click at start button
  2. click at run
  3. type control
  4. search and double click the power options.
  5. Set power scheme as presentation.
If this not helpful then contact to me again by commenting. Thanks for using Fixya.
4helpful
2answers
In my gigabyte g41-combo mother board sound driver installed but sound is coming
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
