Christoph Smit Posted on Mar 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I've recently purchased an Olympia X-L12 electric typewriter. I have 2 problems with it: (a) Lowercase letters are all typed in superscript. (b) The POWER RETURN key does not advance the paper according to the line-spacing setting - it barely moves the paper at all. Could you PLEASE assist?
pawnpower
Level 3:
Master:
  • Master 851 Answers
  • Posted on Mar 08, 2018
 pawnpower
Master
Level 3:
Master:
Answers
851
Questions
Helped
246794
Points
2332
Electric typwriters are 'old' - in general - and old generation completely. they went out of style (and use) as computers and printers became inexpensive and ubiquituous.
now you know why it was sold. it was defective and there are no parts available since it is likely more than 20 years old.
5 Related Answers
Dick O Reilly
  • 3594 Answers
  • Posted on Jan 05, 2008
SOURCE: IBm Wheelwriter 5--6 keys won't advance after typing
Press and hold the code key while pressing the lang key Either "X" of "L" key.
DickyO
Anonymous
  • Posted on Sep 02, 2008
SOURCE: Olympia Mastertype 3 Typewriter
Be sure the pitch selection is correct. If it is set to PS when using a 10,12 or 15 pitch wheel it will select incorrect letters.
Anonymous
  • Posted on Oct 08, 2008
SOURCE: Olympia Startype 3 Typewriter
I need a manual for the olympia startype 3 typewriter. How do I optain that?
Anonymous
  • 45 Answers
  • Posted on Jun 07, 2009
SOURCE: bought a great smith corona coronet electric 12
Try going to www.willrepairservice.com for a manual for your Smith Corona typewriter. Or, you can go to Google and type in "Will Repair Service", go to the first link displayed in the results. Best of luck to you!
Anonymous
  • 51 Answers
  • Posted on Jan 23, 2011
SOURCE: I have an old electric
i have the same problem!!! if you find a solution, please email me at [email protected]! i really want to know whats wrong, email me if you know!
Olympia Startype 3 occasionally types double vertical line and spacing is changing between letters
Check the printwheel for any broken or bent spokes. vertical lines means the wheel is between letters so either a problem with printwheel or something preventing wheel from turning normally.
Where can I find the vertical typebar adjustment?
Guessing the buffer resting stops for smalls and possibly capitals have moved ir come loose? They should be adjustable with a small spanner and screwdriver. Or if not adjustable you might have to slightly slightly bend the resting stops! However before doing any off the a both check the plate under machine where the shift lock rests. That might be very loose abd give some similar problems. Best
Which typewriter ribbon do I buy
If the spools are 2" in diameter have a 1/8" hole in the center with 4 or 5 smsller holes around it this is a pretty standard fabric ribbon we have them in stock if it is different sem\nd the spools to us and we will wind a new ribbon on them.
DickyO
216-269-3918
1helpful
2answers
Olympia XL501 typewriter does not type letters on keyboard
make sure ribbon and corr. tape are installed correctly
" " nothing is interfering with the free rotation of the printwheel
check to make sure the "pitch" selection matches the printwheel
if these seem ok seek a repair shop
2answers
Top Olympia Office Equipment & Supplies Experts
Mitch Vass
Mitch Vass
NOEL
NOEL
jws1013
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
