Question about Huawei Computers & Internet
Does Huawei S5700 Series PoE switch support Huawei PDC-650WA-BE DC power supply?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 15 Answers
Huawei S5700-28P-PWR-LI only can be equipped with AC 110V-220V power supply.Only Huawei S5720-28X-PWR-SI, S5720-52X-PWR-SI, S5720-36C-PWR-EI, S5720-56C-PWR-EI can support Huawei PDC-650WA-BE (650W DC PoE module)
Posted on Mar 08, 2018
2 Suggested Answers
6ya staff
SOURCE:
MaggieWang
  • 18 Answers
SOURCE: Does Huawei S5700-28P-PWR-LI support PoE DC power supply?
No, Huawei S5700 series PoE switch only has AC power supply.
Posted on Mar 07, 2018
Which Huawei switch models support Huawei PDC-650WA-BE 650W DC PoE module?
you could always contact your Huawei dealer and ask them, if that doesn't seem tooooooo obvious to try doing.
Mar 08, 2018 | Huawei Computers & Internet
How Do I Know that the Huawei S5700 series switch's Fan Operates Normally in Intelligent Mode?
The fans can work in the intelligent mode or forcible mode.
In the intelligent mode, the fans start to operate only when the ambient temperature goes higher than a specified value. In V200R003C00 and later versions, you can run the display fan speed-adjust threshold minus command on the switches that use the intelligent heat dissipation mode to view the temperature thresholds for the fans to start and stop running. The set fan speed-adjust threshold minus command can be used to lower these temperature thresholds.
Intelligent heat dissipation:
Huawei S5700-24TP-SI-AC
Huawei S5700-24TP-SI-DC
Huawei S5700-48TP-SI-AC
Huawei S5700-48TP-SI-DC
Sep 14, 2017 | Huawei Computers & Internet
Does Huawei S6720 Switch has 600W DC power supply?
In fact, Huawei S6720 Switch has with 600W AC power supply, 350W DC power supply.
qq??20170907163228-2unbjz2gdcyqx1b141tbj330-2-0.png You can check in http://itprice.com/
Jun 28, 2017 | Huawei Computers & Internet
WHat's the difference between Huawei S5700-28P-LI-AC and Huawei S5720-28X-SI-AC?
Hello, you can also check this two model in Router-Switch, founded in 2002, is one of the biggest Global Network Hardware Supplier.
S5700 28P LI AC
S5720 28X SI AC
Jun 07, 2017 | Huawei Computers & Internet
Will the PoE Function of S2700/S3700/S5700 PoE Switches Be Affected When a 110 V Power Source Is Used?
When using Huawei power supply units, Huawei fixed switches supports 110 V AC input power. The power consumption of most powered devices (PDs) is 4 W to 5 W; therefore, 250 W and 500 W power supply units can provide sufficient PoE power for PDs.
NOTE:
All fixed PoE switches except the S2700-9TP-PWR-EI, S2750-20TP-PWR-EI-AC, S2750-28TP-PWR-EI-AC, S2751-28TP-PWR-EI-AC, S5700-10P-PWR-LI-AC, S5700-28P-PWR-LI-AC, S5700-28TP-PWR-LI-AC, S5700S-28P-PWR-LI-AC, S5701-28TP-PWR-LI-AC, S5700-52P-PWR-LI-AC, S5700-28X-PWR-LI-AC, and S5700-52X-PWR-LI-AC support double PoE power supply units.
Jan 10, 2017 | Computers & Internet
Can AC and DC Power Modules Be Used in the Same Switch?
Fixed Switches Product Series Model AC and DC Power Module Mixing S3700/S5700/S6700 S3700-26C-HI Supported S5710-28C-EI Supported S5710-52C-EI Supported S5700-28C-HI Supported S5700-28C-HI-24S Supported S5700-EI (non-PoE) Supported in V200R005 S5700-SI (non-PoE) Supported in V200R005 S6700 Supported in V200R005 S5710-HI AC and DC power modules cannot be used together, but 350 W and 1150 W AC power modules can be used in one switch. S5720-HI Supported Modular Switches · When a switch does not use a PoE power module:
AC and DC power modules cannot be used together in the same type of power slots. Power modules with different power values cannot be used together either.
· When a switch uses a PoE power module:
Version PoE Power Module System Power Module V200R005C00 and earlier versions AC AC DC power module not supported - V200R006C00 and later versions AC AC DC DC AC DC ·
AC and DC power modules cannot be installed in the slots of the same type (system or PoE) in the same switch, and the power modules of different power values cannot be used in the same switch.
S5720 Switch Thunder link com
Oct 27, 2016 | AC Cars & Trucks
Does the S5700 Interface Support 100M Optical Modules?
Fixed optical interfaces on the S5700EI, S5700SI, S5710LI, and S5700HI support 100M optical modules, while interfaces on extended front cards do not support 100M optical modules.
In the S5700LI series, only the S5700-28X-LI-24S-AC, S5701-28X-LI-24S-AC, S5700-52XLI- 48CS-AC, and S5700-28X-LI-24S-DC support 100M optical modules on their GE interfaces.
The S5710EI series switches support 100M optical modules only on their combo interfaces.
When a GE optical interface of the S5700 works at 1000 Mbit/s, it can only use a 1000M optical module. When the interface works at 100 Mbit/s, it can use either a 100M optical module or a 1000M optical module.
Hope can help you!
S5700 28C PWR SI Price Buy Huawei S5700 28C PWR switch Huanetwork com
Jun 04, 2014 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
Top Huawei Computers & Internet Experts
Ekse
gaucherre
Marvin
Marvin
Are you a Huawei Computer and Internet Expert? Answer questions, earn points and help others
