SOURCE: won't focus
If the camera was dropped, it is possible that something was knocked out of place. That sounds very likely in your case. You should also make sure that the batteries are good. I have a Kodak camera that uses rechargeable AA cells, and they do not last long at all! Mine is a C-743, which has an actual viewfinder, though I suspect yours only has the LCD screen. Those idiots at Kodak think that cameras don't need those anymore, now that they have image stability programs. THEY ARE WRONG!
You may need a repair so expensive that you should consider trading it in for a newer model. These days it is hard to justify the cost of repairing a camera.
Back in the days of the Retina IIIC, Kodak sold some great cameras, and frankly I own two Kodaks now myself, a C-743 which is a pile of junk, and a Z-712 which I love. I believe that Kodak has some of the best image quality available on a digital camera, because they were one of the first camera companies to learn how to tame the contrasty CCD that actually takes the picture in these digital cameras....
SOURCE: FE-280 Lens Blurry Photos and no zoom turns off
You have a bad lens. Unless the camera is in warranty the cost of repairing the lens is higher than the value of your camera. The strange noise you hear is the lens motor trying to move the lens. One solution is to blow compressed air around the lens. Sometimes dust and dirt may jam the lens.
SOURCE: My camera shuts off when I my zoom is nearly halfway through
Make sure your batter is fully charged, and is not bad. This kind of reaction can happen with a weak battery or partly charged.
If that is not it, then the camera needs repair.
SOURCE: THE DIGITAL ZOOM APPEARS NOT TO WORK. MAGNIFYING
Digital zoom magnifies the pixels to seem like you're getting closer to the subject but you're not. The larger the pixels, the worse the picture will look. You should never use the digital zoom (most people disable it). Only use the optical zoom.
