I put in *72*15099945005 and recording said call forwarding was o.j. but then got busy signal. Cell is paired to base unit.
Have one of these bluetooth answering systems. they link to your cell phone to allow it to be used on cell headset mode instead of hunting for a handset. Handy but I have gone away from that after a year. The forwarding your are talking about is not initiated from the cell phone (I guess it could be) but from a cordless handset. And if properly paired, why do it? Your cell phone responds to the base and allows all functions. Answer, place calls etc. From the land line not your sell phone.
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
SOURCE: Call forwarding
I don't know if you've got this sorted yet or if you're still looking for a solution. If you are still looking, try the following:
From the phone the calls currently ring at, try dialling:
7102, followed by the new extension number you want the calls to ring at. You should hear a confirmation tone and then you should be sorted.
To cancel this and go back to normal, at the original phone dial 7100.
Let me know if this works! :)
SOURCE: trying to use multiple base units
It is not possible to set up 2 base units to work with same handset as the base unit and the handset are tagged by their operating frequency, which also works as the privacy filter for the user, so that your neighbors cannot pick up your line and use on your expense. For your requirement you need a DECT system that can support multiple base stations.
SOURCE: How do I change the voice mail prompts to forward to cell phone.
I also cannot locate the "Business Telephone System User Manual" and the link provided by cnavarro no longer appears to work. I am trying to find a detailed instruction manual on the KX-T7630. Most urgently I need to know how to divert a call from one phone if it is not answered after a certain amount of rings, to another phone.
Any help is greatly appreciated.
SOURCE: kx-tg5632 how do i forward call to my cell
Help me guys!!When using call fwd to outside from a custom service on a TVM50 the call will not transfer. I am using many manual in TVM50 but settings are not working. I have tried many changes to timers, Cos ets and reset help me !! TDA100 for PBX model TVM50 for voice processing system
regards Tsegi
