There are two methods to change iPhone ringtone:
From computer:
Step 1: Download and install the latest iTunes on your computer.
Step 2: Simply add the sound file to iTunes and then you can find it in your library. Then select the loaded sound file in iTunes and click File >> Convert >> Create AAC Version. Wait for some seconds, the MP3 would be converted to AAC format.
Step 3: Open the directory of converted MP3. Then, right click on the AAC file and you can rename and change the file extension to .m4r.
Step 4: Use Leawo iTransfer to transfer the ringtone from computer to your iPhone without data loss.
From iPhone:
Step 1: Download and install GarageBand on your iPhone.
Step 2: Choose an instrument and click the project icon.
Step 3: Add the source song to GarageBand. Then tap on the track and you can edit the track as you like to trim in shorter than 40 seconds.
Step 4: Long press My Songs and you can find a Share option. Then select Ringtone as the exported style to assign the song as iPhone ringtone.
You can read on more detailed steps with pictures on: https://www.leawo.org/entips/how-to-add-ringtones-to-iphone.html?fixya=1409
If you want to change the ringtone on your iPhone, the steps as below will help you to perform this task in an easy way.
1. Tap on "Settings" on the home screen of your iPhone. Then choose the option "Sounds & Haptics".
2. Tap on "Ringtone" in the section of Sounds and Vibration Patterns. Multiple ringtones can be found in the list and you also can see the current ringtone which is being used.
3. In this "Ringtone" screen, all ringtones on your iPhone can be seen here, you can select the ringtone you like whatever the default ringtone or the purchased ringtone or the custom ringtone.
4. You will see Alert Tones when sliding down the screen of your iPhone, Alert Tones are usually applicable to alarms or other notification, but they can also be applied to ringtones as well.
5. You can preview the ringtones that you have chosen, as the ringtone will play once you tap on it, then you can determine whether this ringtone suits your need.
6. Once you have selected the ringtone as default for iPhone, the checkmark beside the ringtone must exist and then you can go away from this screen, then tap on "Sounds & Haptics in the previous screen. Finally, your selected ringtone will be saved automatically.
After that, the ringtone you just set will play when you receive a call.
For more detail, check: How to Add Ringtones to iPhone
