Question about Behringer Music
I have the inuke1000 with a behringer ub2222 and sometimes while playing my left channel cuts out for a few sec or if i start adjusting the left main volume slider. My mixer and amp are new and clean
  • 43 Answers
Check out the left channel with an ohmmeter. Be sure to unplug it from everything. Even though it's newit still could be defective.
Posted on Jan 10, 2019
6ya staff
SOURCE:
Anonymous
  • 17 Answers
SOURCE: PEAVEY 6 CHANNEL MIXER (PV6) - Right Fader Crackles
its obvious that the fader in question needs replacing ..parts are available from www.peavey.com
Posted on Feb 02, 2009
Fred Yearian
  • 5603 Answers
SOURCE: With volume set at
Plug a set of headphones into the EFFECTS SEND jack... only one side will have sound... now see if the level varies at that point... Note that the soumd will not be too loud and only in one ear... but we are wanting to find out if it varies at this point.
Posted on Jan 16, 2011
Fred Yearian
  • 5603 Answers
SOURCE: Behringer pmp4000; not getting much
You would get about 200 Watts RMS per side using 8 ohm speakers. "Not much volume" is very relative. With the two 12 inch speakers you should be able to fill a 600 to 1000 sq ft room nocely.
Posted on Mar 05, 2011
Fred Yearian
  • 5603 Answers
SOURCE: I have a Behringer PMP
There are NO "yellow" overload LED's period. The clip or overload RED LED's are just above the PFL buttons for selecting a solo channel. There are "yellow" signal received lights (level set) up near the trim controls. In normal operation these will light when signal is received. Here is schematic for the PMP5000 which is really identical for the 6000.
http://elektrotanya.com/behringer_europower-p0569_hca2400_sps1000_dpx_pmp-1280s_5000_sch.pdf/download.html This has part of the DSP and PS and the PA circuits.
Scroll down to "get manual" and click on it to download. Ignore other download links on the page.
Try turning off the Phantom power if it might be on... If that stops the hum, something is the matter with the bypasses feeding Phantom power to those channels... Possible problem might be shorting of one of the coupling caps at the preamp input. The PMH5000 drawings are more accurate at the input circuits. You will note that the level set LED's are the yellows, and the clip/PFL LED's are the red ones. I suspect that RF bypass caps such as C110 or C121 (example typical for channel one) might be shorted. This makes noise on the Phantom power line unbalanced and will get into the channel where one of these caps is shorted. Do a test: Plug a shorting jack that shorts the tip to the sleeve intot he inssert for the channel. With the LOW CUT button up, observe is the level set LED for that channel dims or goes out. If it does, then I supect you have a shorted RF bypass cap at the input..The next test involves driving a KNOWN balanced signal into the XLR jack and using a TRS in tthe inout 1/4 inch, test the levels with an oscilloscope to verify the hot and the return have equal amplitudes. I they don't, congratualtions you have to tear the main board out... lots of knobs and screws to access the inout circuits and verifuy the cause... it could ALSO be a bad transistor in the inout pair, etc...
Posted on Sep 25, 2011
Fred Yearian
  • 5603 Answers
SOURCE: Behringer pmp4000 keeps dropping an ouput channel while playing live!
The PMP has an electronic overload protection. If you overload one or the other of the outputs, it trips the protector and you have to cycle the power off for a bit to reset it. You haven't mentioned what speakers you have. Be aware that the impedance can be no lower than 4 ohms on either channel. In addition, I have seen some particular speakers that have transformer attentuators in them that this amp is NOT happy driving. You could not attach more than two 8 ohm speakers to each of the outputs without tripping the protector.
Posted on Mar 03, 2012
My behringer eurodesk sx3242fx has a problem with the MAIN OUT XLR (L&R)....LEFT side is not working what is the problem?
Process of elimination needed...start by checking cables and amplifier channels. Also make sure the mic channel on the mixer does not have the left and right "Pan" control turned to the extreme "R" (no left output).
May 26, 2014 | Music
Why does the left channel of mixer randomly crackle, distort, and/or cut-out?
left channel control pot dirty most likely. is there a slider type pot on channel? this would have to be cleaned with dustoff spray.
May 06, 2012 | Behringer Music
Behringer sx3242fx not working .i need circuit diagram .
Behringer will not release schematics unless you are an authorized service agent... however, sometimes you can make do with the few schematics floating around... What is the problem with the unit? They typically use a switching power supply and the schematics of those aree usually similar enough to repair them.
Sep 09, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
I can be playing music through this, and suddenly, all sound cuts out. Sometimes, if I solo a channel, I can hear that channel.
We need more information about how you are using this... specifically what is it connected to and with what type cables... You MUST use balanced lines either XLR or TRS cables. You MUST power this from the same receptacle as amps or other connected equipment. Use of plain old guitar type cables as audio interconnects from the output of this is a big no-no.
Aug 14, 2011 | Behringer XENYX 2442FX Mixer
I have a Behringer PMP 6000 that I just bought. With the power amp switch in Main L/Main R it works fine, but if I switch it to Main/Mon, only the Mon works, nothing from the Main. Bridge mode doesn't...
Bridge mode you use chan B (left connector on the back) using a SPECIALLY wired Speakon. The impedance of a speaker connected as such CANNOT be LESS than 8 ohms.
In the Main/Mon mode, the two amplifiers are separated in function. The monitor knobs for EACH channel input control the mix sent to Channel A which is for the monitor speakers. The Mon1 controls the level sent to Output A for the monitor speakers. Mon2 fader is NOT used.
The individual channel faders control the main mix and the Main fader controls the level sent to Output B which goes to the main speakers.
Apr 02, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Sound cutting out
You may be having early stages of arc over in the main amp. This leads to catastrophic failure of the power amp section (usually the rearward one) and sometimes the power supply.
Facing the back of theunit, usually the left speakon connector is the one that connects to the section that fails.
The arcing is between two layers of a multi-layer board.
Note, if you smell smoke or pop a fuse DO NOT continue to use the device but get immediate servicing.
Jul 10, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
How to get the effects to work on the mixer
This is in general for Behringer mixers since you did NOT tell us a model number...
To use the effects you adjust the FX knob for EACH channel for the amount of the mic or input you want to send to effects from that channel. This is the "send" mix.
You dial in one of the effects based on the list near the effects selection window with the selector knob and the number will change and start flashing. You press down on the selection knob which will enter the new effects number and the number will be solid and not flashing.
Then there is a knob to select how much of the OUTPUT of the effects you want to go to the main and sometimes one for the amount to the monitors.
That is all there is to it. The effects can be gated by a foot switch input if you desire.
It is a good idea to include a model number as your thing is posted as if it is a PMP3000 mixer.
May 11, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I have the Eurolive B212A speaker,and the Xenyx 1202fx.I want to play my Ipod using this set up.Please help with connection
The Ipod is stereo and your speaker is not, so don't expect stereo.
Find a 1/8 inch stereo cable that splits the two channels into individual cables and enter those into two channels of the 1202 mixer. You might find a cable that goes from the 1/8 inch stereo and splits to two RCA type jacks which you have to either find RCA inpouts on your mixer or get two RCA to 1/4 inch adapters.
Crank the pan controls clear to the left on those two channels. Run a cable from the 1202 left main out to your speaker input.
Adjust the controls as needed.
Jan 03, 2010 | Behringer Music
Behringer UB1222FX Pro: Problem With Left Channel Cutting Out
Try cleaning al of the sliders using an electronics cleaning spray. Choose one that contains a lubricant as well. Dirty sliders can cause this especially at low volume levels. If that does not resolve the provblem, update this and we'll look further.
Dan
Apr 09, 2009 | Behringer Music
Aug 09, 2008 | Peavey 32fx USB 32 Channel Mixer
Music Logo
Top Behringer Music Experts
Michial Gueffroy
Chickenwatt
Level 1 Expert
Ric Weide
Ric Weide
Level 1 Expert
Are you a Behringer Music Expert? Answer questions, earn points and help others
