Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device./
SOURCE: logitech Harmony 720
This remote is a learning remote it does not exactly take "codes" You need to download software to use this remote you can get this software here:
http://www.logitech.com/index.cfm/440/370&cl=us,en?osid=1&file=
hope that helps!
SOURCE: HOW DO I GET MY LOGITECH 200 REMOTE TO WORK WITH MY CURTIS LCD2244A TELEVISION
Setup codes for Curtis TV are: 0031 0105 0130 0004 0009 0000 0049... 0109 0358 0001 0015
Direct Code Entry
