The washing cycles (seems to be most of them) just keep spinning for hours with soap in and don't end. Have had to manually put it onto the fast spin cycle to finish it off.
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
It only does it on the wash. I put a cycle on last night before I went to bed and it was still spinning (could see the foam in the drum) this morning when I woke up. The dryer is working fine.
need more info does it do this on the wash as well
