SOURCE: my new Edimax BR-6428nS cant connect to my
Do you mean DSL line? Can,t connect using that line.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
There is a great article at Working with Windows Wireless Networks
SOURCE: how to set up my
http://www.edimax.com/en/produce_detail.php?pd_id=371&pl1_id=24&pl2_id=89#03
If you click on the link that i provided, go to the bottom of the page where you see the download area. In this area you can select the install guide and download it or print it out for instructions. there is also the driver and the firmware downloads in case you need them. Also a full manual is there if needed.
SOURCE: my friend just give me her wirless broadband
It will have to be reset to factory defaults, and then re-configured
http://www.edimax.com/images/Image/FAQ/Router/General-Router/ForgetPassword-Router.pdf
Check the connection type is not "Connect on Demand".
Check the
Idle Time Out setting is not used.
This specifies the amount of time the router waits before shutting down an idle connection. This option is only available when "Connect on Demand" is selected. See the manual
See
