SOURCE: programing for uniden bearcat scanner bc 144xl
danval, I looked up a pic of your scanner and it is pretty straightforward. If it is the 16 channel I was looking at, here is the step by step programming.
1- Push manual button to go to the channel you want to start programming.
2- Enter the freq number in.
3- Push the E button to enter it in the memory.
4- To review what you programmed, push the Review button.
5- Use manual button to step to next channel and start over from #2
That should get you started with the scanning hobby.
The scanner has a Priority button that when activated will stop scanning and go immediatly to the priority channel if someone keys their mic.
If you need freq's (or more of) for your area, go here and click on your state and county and it'll give you a complete listing.
http://www.radioreference.com/apps/db/
Hope this helps you out, let us know,, Mechanic
SOURCE: how to program and delete uniden bearcat scanner 210 XWneed to c
I can't locate information specific to the 210XW, but hopefully this generic Bearcat programming info will help:
1. Press the MANUAL key to advance to the channel that you wish to reprogram.
2. Enter the new frequency, including decimal point.
3. Press the ENTER or E key.
4. Start over with step one to continue programming channels.
SOURCE: I have a Uniden bearcat scanner and cant remember
Although you didn't specify a model, your problem is listed in the BC95XLT section, so here is a link to the manual for that scanner. It's a pdf file that you can download/print for future reference.
http://uniden.com/pdf/BC95XLTom.pdf
If this is not the correct model you can find manuals for most recent Uniden scanners on the same site.
