SOURCE: fuses
These heating elements use limiters to control the temp range and here is a link that shows where they are http://www.pcappliancerepair.com/model-display.php Hope this helps...
SOURCE: whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
SOURCE: Whirlpool Oven, Ceran stove top
I want to say that since I posted my original problem with black spots appearing on the Schott Ceran top, I took pictures of the top and attached them to a complaint sent to Maytag. Approximately 3 days later, a Maytag representative phoned and offered a brand new top-basically stating that there is a fault with the tops. They would not pay for the labor to replace the top. My husband downloaded the instructions from Maytag website and installed it himself. These spots actually appear from within the surface and are not the result of a boil over, etc. The spots on my burner grew to the width of the burner. If you search the internet, you will see many others with the same problem with the Schott Ceran tops. I will never buy another!
SOURCE: schott ceran stove top from Sears, all burners are
Check here...
http://www.schottceran.com/
Also try and find a product called "KickIT" of get it here.
http://www.muleheadbrand.com/pdf/degrease-it-etc--web.pdf
This is an industrial degreaser I used at work. Be careful with it as it will peel paint! But is does a great job cleaning the oven top. Spray, let it set a few and spray again. You may still need the scraper, but it will come clean much easier.
Added TIP: Got one of those reusable filters in your window AC unit?
Take it outside and spray it down with this full strength. Hose it off when you are done and it will look like new. I also use it to clean smoke residue and crud off of computers (caeses) for a fairly new look.
