We cannot releasetgebottom of our supervac to empty it. Which button do we press- none seem to work though have done it previously.
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: the 'go to previous' button ( < ) didn't work.
sim 2 is not working
Posted on Dec 10, 2009
How do release the bottom to empty our supervac model no. 732000-A
Morphy Richards SuperVac 732000 User Manual
Click on above link for the user manual. You can read online or print out.
Good luck,
Semper Fi,
Z
Mar 02, 2018 | Vacuums
Whirlpool 6th sense wont start cycle
I have the same problem. Look at the previous post, it seems to be the motor brush worn out. I've opened up the machine and checked. The carbon brush remains very little. I am trying to find out a replacement brush
Dec 27, 2013 | Whirlpool AWM6100 Front Load Washer
Answer always appearing
Minus and change-sign are two completely different things. Minus is used to subtract one number from another. When you press minus when the input line is empty, your telling the calculator to subtract. The only way it can subtract the number you're about to put in is to subtract it from something else, and that something else is the previous answer, hence the "Ans."
If you want to input a negative number, use the change-sign key. If you want to subtract one number from another number, use the minus key.
Try pressing the plus key when the input line is empty. You'll get Ans+ in this case as well, The same with multiply and divide, among others, and for the same reason.
Sep 23, 2013 | Texas Instruments TI-84 Plus Calculator
The red light on my hayden 3600 vacuum won't go off
I have a 6000 and it does the same thing. I simply unplug the unit and plug it back in after cleaning the filter and dumping the cannister. That seems to reset the warning system.
Jul 06, 2009 | Hayden Industries SuperVac 6000 Central...
Can not get 3 speakers on my samsung home theater to work!
There are a few settings that will just give you a stereo output. The first one is with the Pro Logic II. If you press the PLII Mode button on the remote it will go through a series of settings from MUSIC ➞ CINEMA ➞ PRO LOGIC ➞ MATRIX ➞STEREO ➞ MUSIC. Pro Logic setting will only produce sound from the front speakers and Stereo from the front speakers and the sub. Put it on Matrix for 5.1 surround sound.
Also for speaker settings follow the instructions below.
Signal outputs and frequency responses from the speakers will automatically be adjusted according to your speaker configuration and whether certain speakers are used or not.
In Stop mode, press the MENU button.
Press the Cursor down button to move to Audio and then press the ENTER button.
In the SPEAKER SETUP, press the ENTER button again.
Press the Cursor button to move to the desired speaker and then press the ENTER button.
For C, SL, and SR, each time the button is pressed, the mode switches alternately as follows : SMALL ➞ NONE.
For L and R, the mode is set to SMALL.
SMALL : Select this when using the speakers.
NONE : Select this when no speaker is connected.
Press the RETURN button to return to the previous level.
Press the EXIT button to exit the setup screen.
It also seems that with this system, if you are on 5.1 surround but your music source is only in stereo, you will only hear stereo.
Nov 20, 2008 | Samsung HT-Z310T Theater System
False empty ink cartridge message
There seemed to be a jam that was unrelated to the cartridges themselves. The print head seemed to be incorrectly shifted upward; thus the cause of the awkward noises it was making. After simply fiddling with the placement to try to physically realign it, I had the printer unplugged during this process, it seemed to snap into another position. I plugged the printer back in, powered it on, followed the reset method; hold cancel, ok, black, and color, and it was good as new. The only thing left to do was to let the printer follow through with its normal routine when reset. With the exception of an odd noise I have not been able to isolate, there is nothing further wrong with the device. All the features work just as well as they used to. I don't know if this is helpful being that other problems people encountered were faulty ink levels, but the method worked for me.
Nov 17, 2008 | HP Photosmart 3310 Printer
Hayden Supervac 3600
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11860&thid=808510
Posted by kdm0 on Jul 20, 2008
Hi, I have a Hayden Supervac 3600 central vac system in a house I just purchased. The Amber light indicating that it needs regular maintenance is on. I have cleaned and serviced the motor, everything is fine and suction is well. How do I reset the service light? The reset button seems to do nothing. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I heard of this happening before and you need to refer to the owner’s manual and or to contact the factory or manufacturer of which I will provide to you @ the end of this question. There may be some type of rely switch or board that might need replacing but check with the factory. If you need further help please refer to a local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.haydenvac.com/company/company.html
Customer Service 1-800-461-5300
Company Phone # 1-705-726-3361
Company Fax 3 1-705-726-2186
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 20, 2008 | Hayden Industries SuperVac 3600 Central...
Brother fax machine 8360p
It seems that someone has sent a large fax that has filled the memory. What they may have done is accidentally programmed one of the buttons to send to #342. This is easily done, if those keys are pressed and then an empty program button is pressed right after. You will have to remove the program from the que 1st of all, then remove the program from the button.
Jun 09, 2008 | Brother Office Equipment & Supplies
20 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
