Exercise & Fitness Logo
Mary Beth Marquard Posted on Mar 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do not have ownes manual. how to correct error LUbE on Xterra TR150 treadmill
Regan
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 16, 2020
Regan
Contributor
Level 1:
Answers
Questions
0
Helped
1406
Points
The LUBE message won’t go away even after I have lubed the treadmill and reset the treadmill. I will run on it for 7 minutes then the LUBE message comes up again.
Jean DeLauche
Level 3:
  • Master 2,911 Answers
  • Posted on Mar 02, 2018
Jean DeLauche
Master
Level 3:
Answers
2911
Questions
Helped
974309
Points
13029
Hello, Mary -
I went to the Xterra Fitness homepage:
http://www.xterrafitness.com/
Then, I clicked on the Support link in the upper right corner of the homepage.
That brought me to this page:
http://www.xterrafitness.com/support?ref=top-nav
Where I saw the link for "I Need A Service Document".
I chose that link.
That choice brings you here:
http://www.xterrafitness.com/support/supportdocs/
I do not see your model treadmill listed on that page. I suspect LUbe means your treadmill needs lubricating. The General Maintenace instrucitions (link the last one in the first column on the Support Documents page) will give you some information.
This is the link to the Contact Us page for Xterra Fitness:
http://www.xterrafitness.com/contacts/?ref=footer-link
You may want to send an email to find out how you can obtain an owner's manual for your model of treadmill.
Best wishes.
1 Related Answer
sunny62mahes
Sunil Maheshwari
  • 7 Answers
  • Posted on Jan 08, 2015
SOURCE: Where does one lube the belt on this treadmill?
Belt is the surface you walk/run on.lift it up in the Centre and spray lube on the board belt runs on
REEBOK GT30 TREADMILL. It has ERROR E2. What does this mean please?
E2 Error usually indicates that the treadmill is overloaded and applies to various models like TR150, TRX1000 and TR 200. To fix this problem, check if your treadmill motor is overheating. Signs of an overheated motor include; grinding noise, motor produces a burning smell and inconsistent operation speeds.
Treadmill repair : r/fixit
Reddit · r/fixit 3 comments · 4 years ago Hi i have a reebok one gt30 treadmill bought in 2016. Recently at ... Start googling error codes and find out what E2 means. Upvote 2
Which part of my broken treadmill should I try replacing? - Reddit
Apr 18, 2020
Urevo 2-in-1 giving e10 error message- did you encounter this ...
Oct 10, 2022
Need help with Sole F63 treadmill error code - Reddit
Nov 21, 2022
More results from www.reddit.com
Reebok jet 300 treadmill e02 error - motor output dc is 11v on ...
All About Circuits https://forum.allaboutcircuits.com > threads > reebok-j...
Jan 9, 2023 - It seems to me to be a problem in the circuit that gives feedback to the processor about the voltage in the motor, error02 and does not arm the ...
Missing: GT30 ‎' Show results with: GT30
Treadmill Support - Reebok Fitness
reebokfitness.info https://www.reebokfitness.info > treadmill-support
View user manuals, assembly guides, instruction books, and technical support videos for all Reebok treadmills, including how to reduce static shock.
Xterra TR3.0 error code 5
Quoting from XTERRA on website
The E5 Error is specific to the TR2000e and the TR3000e treadmills.
The error code triggers when an object is detected by the folding sensors on the underside of the treadmill. The folding sensors look like small trapezoids: two on the back and two on the front. Make sure there are no foreign objects underneath the treadmill. If no objects are present, inspect the sensors for damage. If the problem persists, please contact customer service.
How do I resolve Error 5 on my XTERRA Treadmill
Customer service department 877.654.3837 x4 or fill out a customer service request form.
https://www.lifespanfitness.com/fitness/resources/articles/what-does-your-treadmills-error-code-mean
Need Reebok Z7 maintenance manual
If you wish to get some details about treadmill maintenance ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
What does lube bell mean
Either your treadmill has a typo or....well, it's LUBE BELT.
Go here: http://www.horizonfitness.com/support/customer-support
Download the manual for specific model and it will describe how to lube the belt. There may be a RESET procedure required to turn off the message and turn on the treadmill.
GL,
Td
Error 6 message on xterra 3.0 treadmill
I have the same problem... It doesnt work.
Xterra tr3.0
New xterra trendmill will not start says error 5 help
Treadmill will not start up error comes up in window
please LUBE the deck belt with silicone or was see the owner manuals and proceed according. However if after you did lube the problem remain, is TIME to replace the old deck board.
God bless you
2answers
Appeared on the screen of the device that need oil, but does not have a place to fill the place of oil????
The only place to oil is under the walk belt. You dont need to worry about it. If you want to, you can order a kit from iconservice.com.
Hope this helps, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
