Question about Samsung Televison & Video
SCREEN FLICKERING. I have a Samsung 55" Smart TV with Model No. UA55D8000YR. Now it showing Blank screen with Logo flickering. The power supply module in this tv is part number BN44-00428C Please advise if it is possible to solve the issue by cutting any Jumper connection ? Please advise the Jumper number too.
    Master:
  • Samsung Master
  • 362 Answers
  • Samsung Master
  • 737 Answers
Cutting a jumper will not fix this. the TV needs proper troubleshooting to determine if the issue is power or with the digital board.
Posted on Mar 02, 2018
6ya staff
SOURCE:
Anonymous
  • 579 Answers
SOURCE: Samsung TV flickering
This is an unusual failure of a non obvious part in the power supply putting noise into the circuitry of the TV.
you either need a competant tech to work on it or if you are good at connecting up cabling just swap out all the guts.
call Module Exchange at 972-298-1212
Posted on Jan 01, 2008
Anonymous
  • 92 Answers
SOURCE: LG 42LC2DB LCD TV Flickers when Ps3 is connected via HDMI port
Make sure you have the PS3 set to the correct frequency for the TV. Many cannot accept 1080p / 24fps etc.
Try different settings.
I hope this helps.
Posted on Mar 28, 2009
Anonymous
  • 60 Answers
SOURCE: My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Posted on Aug 23, 2009
dick davis
  • 610 Answers
SOURCE: LE46M86BD SAMSUNG LCD Picture issues (turning off after 5 secs)
you will need a tech to isolate the fault. could be power supply board or the main board but I suspect it is the lcd panel itself that is failing.
Posted on Oct 30, 2009
yammy_alf
wenceslao alfar
  • 666 Answers
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Posted on Mar 26, 2010
Not Solved 9/17/18 A 9 yr old 55 LG LCD tv I need help with. Model 55LH55-UA w/ black screen exhibiting the following: -turning on tv by remote or on the side, blue ON light comes on, screen is black.
Sounds like you have LED backlights that are going bad and the strips need replacing, its not a real easy job but if you watch some youtube vids they show how to do it.
Sep 16, 2018 | LG Televison & Video
LED television is flickering what is wrong?
Flickering can be adjusted. In rare cases, power board inside it might need replacement. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 21, 2017 | LG Televison & Video
Can a bad power board in a samsung tv cause flickering in the screen?
It sounds like your lamp is getting ready to go out, but you are also correct in the fact that a bad ballast could also make the lamp flicker. I hope this helps.
Feb 19, 2016 | Samsung 60" Series 8 LED HDTV - UN60F8000
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
How do I stop the flickering of my Samsung HD Smart TV screen?
http://www.shopjimmy.com/samsung-bn44-00612b-power-supply-unit.htm
Sep 16, 2015 | Samsung UN55F6300
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. Has been fine . Goes away once in a while. An Ideas what is wrong ?
Main power supply regulator board can cause this. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Televison & Video
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
Hello, I have a lg lcd monitor. w1941s model. when I start my computer, it work for sometime. then it goes blank showing only the LG logo. then the power button doesnot work. it hang up glowing. again
- Flickering screen
- Dim screen
- Slow start
Apr 06, 2014 | LG Computers & Internet
Televison & Video Logo
294 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
