SOURCE: Over the range microwave oven.
This could the problem with door switch if its within warranty get it serviced by the company, if its out of warranty get done local service center replacement of the door switch will around $50 ,Please do not it yourself as there is high voltage parts in it .....................
Good luck....
SOURCE: The fan on our Kenmore microwave oven is not working.
My husband took the unit off the wall looked down into the fan and found a dead mouse keeping the fan from spinning. We removed the dead mouse cleaned up the area. Turned on the oven. The fan worked perfectly. Then he rehung the microwave.
Thanks!
SOURCE: Kenmore Microwave Oven model #401.80082700
Sounds like a bearing is tightening up when it get heated up with use. Then after a cool down period it works normally until using it heats it up again. Eric
SOURCE: microwave oven fan will turn itself on and off
It may be a shorting pad (the hood / vent fan pad) on the keypad or a part on the control board.
Absolutely - If and when an oven
is coming on or doing anything by itself, this is very dangerous and
can result in a fire.
So until it is repaired,
please leave it unplugged or leave the door
open when it's not in use, and please do not leave it running
unattended.
We
regularly repair these control units for customers nationwide by
mail for $39.95 postpaid in about a week or so with a one-year
guarantee.
If you need a new keypad, that would add about $37 to that cost.
Feel free to visit our Web site or contact me directly with your model number and symptoms.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: The vent fan on my
The vent fan is controlled by 2 relays on the control board. Relay #4 is for high speed & relay #5 is for low speed. It sounds like one of the vent fan motor relays on the control board are getting shorted together. Something like this will require replacing the control board. -----------The relay has to be checked.If the relay is shorted it has to be replaced, in some cases the control board itself has to be replaced, as shorted relay also shorts the control board.---------- You can get required parts from repairclinic.com or from sears parts direct.com.The relay has to be bought from local appliance parts store.A local appliance repair tech can provide this relays, as original relays are not available, but they will provide substitute/ compatible relay for that relays. ------- But if relays not helping, then control board is the final option.-------- This will help.Thanks.Helpmech.
