Question about Kenmore Freezers
Kenmore freezer chest, model C67, motor runs, not cooling has sat idle for 10+ years
    Top Expert:
  • Kenmore Master
  • 65,443 Answers
Throw away or call repair service .
Posted on Feb 28, 2018
6ya staff
SOURCE:
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
Anonymous
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
Terry Engel
  • 176 Answers
SOURCE: Used chest freezer not cooling
Slobberlips,
One of two situations has occured with your used freezer:
1: The unit freon needs to be recharged, this happens when you develope a leak in the freon coils, or the unit is old enough that the freon has reached it's usable potential.
2: The compressor may seem to run fine, but in fact, has an internal problem.
My suggestion, return the unit if you can, and walk the isles of your local Menards, Sears, or any other local vendor in your area, and see how much prices have declined for the chest freezer.
The initial investment for a new freezer will offset any problems you might have with any other used unit, and the warranty is always a plus if you do have problems with the new unit.
Hope this helps you out.
Posted on Feb 01, 2009
Anonymous
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Posted on May 01, 2009
Russ South
  • 91 Answers
SOURCE: RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, wgheaven@yahoo.com.au Russ
Posted on Mar 29, 2011
I have whirpool chest freezer defrosted and off for 4 months then turned on 2 red lights going motor is running but not freezing turned up temp to coldest tempurature with amber light on stil the motor...
Since the motor is running, the compressor it is connected to must also be running. The compressor is the thing that provides the cooling under normal circumstances. The only thing I can think of as to why you are not getting cooling is that the refrigerant charge has leaked out of the system. I don't know anything about the red lights you mention.
Aug 25, 2014 | Whirlpool 10 cu. ft. / 283 liter Chest...
My kenmore chest freezer is the garage, the temperature outside is over 30 celsius, the side of the freezer where the motor is is very hot, and some other places on the front and other side is warm to the...
The hot sides is normal, this is how they expel the heat from inside the freezer, sometimes it may help to use a fan to help cool. Also make sure there is about 12" of room around all sides of the freezer .
Aug 22, 2017 | Kenmore 14.8 cu. ft. / 419 liter Chest...
I have a kenmore chest freezer model 19502/19702. I had it unpluged for 5 months. When I plugede it back in the power light flickers. Tryed other outlet. Other then that it seems to be working
We purchased this same Kenmore chest freezer model 19502/19702 in 2010. In less than 2 years the compressor quit. If you do a search on this model you will see dozens of complaints. Don't waste your time or money on this freezer.
Apr 16, 2012 | Kenmore Freezers
Fridge does not cool down
dear sir,
if your freezer,s compressor is running the i think its low gas problem please contect to your service technician for refilling refrigarant .
hope answer the question
thank you
please vote!
Jul 01, 2010 | Engel MT45FU1 Chest Freezer
Kenmore chest freezer does not stay below 30 degrees compressor runs but I don't see a fan to cool the compressor
If your chest freezer is less than 50 years old, it does not have a fan. Cooling coils contact inner walls of freezer compartment, warm coils dissipate heat through outside walls of freezer. If compressor runs, temp is 30+ degrees, gasket is OK, lid not left open, then you have one of two contions: 1. Low capacity compressor 2. Refrigerant leak. Solution to either is to replace freezer. (My opinion: Don't get a Kenmore brand, which generally ties you into poor warranty and slow and poor service.) No matter what brand name is on the freezer, it is most likely manufactured by Electrolux (in St. Cloud, MN) or Haier (from China). Look at the model / serial number plate before purchase to see where it was manufactured. Yes, the USA manufactured ones are better. (and I'm not just saying that because the plant is less than 15 miles from where I am sitting right now)
Jan 01, 2010 | Freezers
1991 Kenmore 16 model 253 in storage for 7 years. Plugged it in and turned it nn last night and seemd to run fine, nice and quiet just like before. Today it is not cold and the comressor seems to be r
If the freezer was stored and not running for 7 years it may have lost coolant.  Since the compressor is running recharging the coolant may fix the problem.  Hot compressor might indicate low coolant since its motor is immersed in it.
May 30, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
I opened my chest freezer and found everything was no longer frozen. I have had the freezer for more then 10 years in the same spot. When I started to unload the meat the motor started up. It seems to be...
Look for a thermostat near the compressor compartment, I first try setting the thermostat up and then down a few times, it may just be stuck and full of dust or dirt. Or just replace it. Very simple, only two or three wires and route the sensor into a sleave.
Mar 11, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Kenmore Chest Freezer C675-18012-1G purchased april 2000
Average freezers last for several years, usually 10 or more. The compressor should not run all of the time, maybe less than 10 to 20 percent of the time if it is working properly. Not sure what you mean by the bipass, some freezer have a manual defrost, and in this mode it will not cool. Insure the location where you have the freezer allows for ample air circulation, sometimes folks put them in little spaces that prevent air circulation to the condensing/compressor unit and they overheat and do not work well and fail very quickly.
Nov 27, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
GE Fridege TBX18J MS not getting cold
hi is the fan motor going in the freezer. if so how long has it been plugged in if more than 24 hrs and the fan is going. it could be that because it sat for 10 years the lines that go inside could have rusted out. so if this is the case its scrap sorry. the appliance doc.
Oct 16, 2008 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Freezers Logo
205 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
