Water Heaters Logo
Dan Gallant Posted on Feb 27, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dip tube size and length and type of end for Rheem PVW50 water heater
Andrew Bugbee
Level 2:
Novelist:
Champion:
  • Expert 267 Answers
  • Posted on Mar 02, 2018
Andrew Bugbee
Expert
Level 2:
Novelist:
Champion:
Answers
267
Questions
Helped
168706
Points
403
All dip tubes on water heaters smaller than 75 gallons are 3/4" male pipe thread to screw into the heater. As for length, go to a plbg supply and ask for a dip tube for a 50 gallon heater, and if it is too long, cut it. I believe that Home Depot also has them right out on the floor for sale.
2 Related Answers
Anonymous
  • 5 Answers
  • Posted on May 01, 2009
SOURCE: Dip Tube
You may want to check the heating elements first. Where I live there is a lot of lime in the water that can coat the elements.
Anonymous
  • 1400 Answers
  • Posted on Jan 06, 2010
SOURCE: We have a Rheem PowerVent, 36,000 water heater for
Is the water heater in a basement or an area thats cold? A water heater jacket may help.
If not ,try setting the heat up a little higher on it until you have more then a 5 min hot shower.
May pay you to get a 100 gallon heater.
Does anyone know the dip tube part number for a Rheem Fury Gas 42VR50-40F water heater? Heater runs out of hot water far too quickly. Thanks!
certain water heaters had a tube that dissolved, you take 1/2 in. copper flare one end of it, drill a1/8 in. hole in pipe 4 in. below flare ,remove cold water nipple on tank install new copper tube, cut tube to 3 inches off bottom of tank depth , reconnect cold water supply you should be good.
2helpful
2answers
I have Rheem Pvw50, 50 gallon water heater installed at home. For the past few days, there is a noise coming out of blower motor. What could be the reason?
Your water heat is at an age that I would recommend replacing the whole unit. That one cannot be too efficient and most likely has sediment built up on the bottom of it pretty bad.
1helpful
2answers
Heating coils were replaced last december and today no hot water for a shower after 5 minutes in the shower. The electric is flying on the meter. Have shut off the circuit breaker for this hot water
Copy following link for tank-type electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#skyrocket
Press reset button located on upper thermostat.
Test elements for short to ground against steel tank.
Clean sediment out of tank. Check for water leak running hot water out of tank.
Replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Power vent rheem mod pvw50 underneath is leaking
You have a water leak coming out of side of tank?
Water heater must be replaced. It is rusted, and could rupture.
Inspect and replace anode rod to prevent rusted tank, so water heater will last longer.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
No hot water at all but power to all elements and to thermostats is there a dip tube in the rheem model 71-40D
Water heater can test for 120V power on elements and thermostats at all times.
That's because thermostats turn off one leg of 240Volt circuit, and not both legs.
You mentioned thermostats and elements, implying two elements and two thermostats, so your water heater is 240Volt.
240Volt breaker might be bad on one leg.
Open following links to troubleshoot
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Yes the water heater has a dip tube.
http://waterheatertimer.org/How-it-works.html
2answers
I am trying to replace the dip tube in my RheemPowerVent water heater but I can't for the life of me figure out how to get the old one out. The treaded metal cold water nipple is screwed into a circular...
1) Rheem power vent series:
http://www.rheem.com/product.aspx?id=C24E3F52-A6A4-4BC7-AF5B-0DF23A7A0263
2) Looking at product over-view manual: It says 'inlet connects directly to a dip tube which directs water to bottom of the tank.'
So it appears that dip tub is connected to heat trap nipple on cold water side
3) Sample manual for Rheem shows exploded parts list
http://globalimageserver.com/fetchDocument.aspx?id=a92c7d0e-8a95-48ba-8810-cd714f33d47a
The exploded view shows cold water nipple separate from dip tube, and shows dip tube gasket, and makes it unclear
4) Manual shows Rheem phone number:
1-800-432-8373
5) You can also post specific questions like this on pro water heater forum: http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project. As general rule, expert will not answer unless they know specific answer, to avoid dissatisfied customer.
Fixya is always less expensive than a service call.
The nipple on the inflow line of my water heater is corroded.
Hello,The nipple/dip tube will come out as one piece so the tube will be needed also.You can make a new dip tube by FLARING a piece of 5/8"copper at one end and use a BRASS 3/4" stock nipple as an OEM replacement.Factory replacement will be hard to find.Good luck!
Dip Tube
Sediment in hot water
With Rheem you have to back to the installer.Most of the heater have ten year warrany.
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
