SOURCE: I have a uniden ubc73xlt handheld scanner,can't
Try a master rest:
If the scanner's display locks up or stops operating
properly, you might need to reset the scanner.
Caution: This procedure clears all the information
you have stored in the scanner. Before you reset the
scanner, try turning it off and on to see if it begins
working properly. Reset the scanner only when you
are sure it is not working properly.
1. Turn off the scanner.
2. While holding down 2, 9, and Hold, turn on the
scanner. It takes about 3 seconds to initialize
and CLEAR appears.
SOURCE: how do you reset a Uniden BC72XLT handheld Scanner
To completely clear out all stored frequencies.
2. While holding down 2, 9 and hold turn on the scanner. It takes about three seconds and you will see the word clear.
SOURCE: I need to program my uniden handheld scanner.
Go to uniden.com and look in customer service/manuals. You will need the model #
SOURCE: How to program an Icom IC-R5 handheld scanner
to store a fcy press BAND to go to your fcy range ie 118.000 airband
dial your fcy ie 127.900(shanwick ocean area control) press and hold V/M for 1 sec, small numbers now blink, dial the memory slot you wish to store into ie 001 then press V/M again for 1sec and this will store 127.900 into mem slot 001. make a list:-
mem number / fcy / mode(am - fm) / station / bank
to prog a fcy into a "bank", press V/M for 1sec - blinking mem numbers - dial mem number ie 001(127.900) press MODE - "bank" flashes past-
-- -- -- -- 001 shows, turn dial to show A-00 this is the first "bank", pressing BAND scrolls through all the alpha "banks" - choose one.. ie A-00 (for airband..) press V/M this puts mem 001 into "bank" A mem slot 00, there are 100 slots in each letter 00 to 99. do this to any fcy you want to scan as a group.
to scan a bank press V/M - small numbers appear -
press BAND to scroll through any "banks" you have created ie A B C D etc (only banks with fcys in will display), press MODE -"bank"- press MODE again and you will start scanning just that "bank" of mem slots.
MODE starts and stops the scan... each letter holds 100 mem slots.. happy scanning!!!
SOURCE: I dont have the code
Follow this link to download/print the operating manual for the BC60XLT:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
Bill B
