Whirlpool slimline dishwasher not working
The pool of water you found under the dishwasher could be an indication that the dishwasher is not draining properly. Here are a few steps you can take to troubleshoot the problem:
Check the dishwasher's filter and clean it if necessary. A clogged filter can prevent the dishwasher from draining properly.
Check the dishwasher's drain hose to make sure it is not kinked or clogged. If it is, you will need to straighten it out or clear the clog.
Check the dishwasher's pump for any obstructions or damage. A damaged or clogged pump can prevent the dishwasher from draining properly.
If none of the above steps resolve the issue, you may need to call a professional appliance repair service to diagnose and fix the problem.
If the dishwasher is still under warranty, you may be able to get it repaired or replaced for free.
