SOURCE: panasonic kx fp 141
What does the machine say your memory level is?
If it is at 100 percent, you do not have any faxes in memory.
All fax machines will hold a job if your out of ink. When the machine detects ink it will, I would say 98 percent of the time, print out any waiting faxes.
SOURCE: panasonic kx-fp 342 papaer jam
paper jam or missfeed always due tothe following:-
1-malefunction of paper feeding system due to broken gears belt chain please check smoth mechnical movement and apply light grease in gears and change any broken part.
2-something is blocking the paper path (staplers-pins)droped inside.
3-malefunction of paper detection micoswitch please confirm free operation for the lever in mechnical one and clean of dust and dirt from optical one,
SOURCE: I need plain paper fax panasonic kx-fp 200 immediately
The refills that fix the kx-fp135 will also fit your model kx fp 200. Office Depot has this and it can be ordered onlin. : http://www.officedepot.com/a/products/288514/Panasonic-KX-FA136-Black-Imaging-Film/
SOURCE: How can I obtain a
Hi!
This is a link that allouds you to read and download for free the user guide manual (in a PDF format) for Panasonic Fax KX FP 121 device: ( http://service.us.panasonic.com/OPERMANPDF/KXFP121.PDF ).
I hope this will help you!
Have a nice day!
*please don't forget to rate my services :)
Testimonial: "thanks, very helpful!!!"
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
