SOURCE: Treo 680 charging light flashes red when disconnected from charger
Have you activated phone yet? When phone is activated and in service it flashes green. It's hard to believe it would flash green without a SIM card, as there is no service...unless AT&T is providing emergency service only and you're getting a flashing green which means you're in range of their towers.
SOURCE: hp mini keyboard shift key 2 does not type @
it has to do with your keyboard setting, currently you are set to the united kingdom keyboard layout, you will need to change this to Unite States settings assuming that you got vista, you will need to do the following
goto control panel
click on regional and language option (there will be a pop up)
click on the keyboard and languages tab
click on the change keyboard button (another pop up will appear)
click on add
and add the United States Keyboard
change the keyboard setting on the upper drop down menu to United States, and then click ok.....this should solve your problem.
SOURCE: Where can I purchase a new mini receiver for my Logitech Wave.
Here is a link to the page on Logitech.com to order the receiver, it runs $10.00 plus shipping.
http://tinyurl.com/y9q82xc
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: Logitech DInovo Edge: When I charge the keyboard
It looks to me like Logitech changed the design a bit. I found no such "CAP", however the problem did in fact lie in the same spot under the sleep button. I found a flat cable that had 6 jumper wires running through it to be the culprit. The cable was made too big, so they bent it to make it fit thus damaging it. I'm going to have to replace it, but just from playing with it a little I got my keyboard to turn on advertising a full charge and when I set it on the base I get a green light off happiness.
SOURCE: My keyboard cannot type any letters. The keyboard
try checking with a different system like your friends.
