When using an external webcam, my Toshiba laptop freezes after a few minutes. needs a hard power reset to recover.
I guess you have the original cd ands drivers with this Webcam?
Since it is external ...follow what Katwal said with only one twist install with the hardware disconnected and then after hook her up
Do you think its due to external webcam ?
You mean that if you dont use webcame it works fine.
If this is the case you just uninstall the webcame drivers from Add/Remove Programmes under Control Panel.
Try to get the latest drivers from webcame manufacture website which suits your windows(OS) and install it again.
looks like hardware. Locks up with any software. It is a Philips 5 MB webcam that comes with V lounge. Also locks up with Skype or the flash plugin in facebook.
Looks like hardware. Fails with any software. It is a Philips 5 MB webcam that comes with Vlounge as software. Also locks up with Skype and flash plugin on Facebook.
Have tried to re-install several times and tried to find new drivers. Device manager always indicates the camera is working fine.
hardward or is it software using same memory conflict try a different application program?
