SOURCE: manque pilotes
J'ai le meme portable, mais je deteste windows Vista. Ce portable est beaucoup trop lent avec Vista! Si vous voulez installer Windows XP, ce portable ce comportera beaucoup mieux. Les pilotes pour XP sont sur ce site (en anglais mais je suis sur que vous pouvez trouver le lien). Le site est : http://www.customautomaticsystems.com/ShowArticle.aspx?ID=35
A.J.
SOURCE: Bonsoir, Description du pb : "Echec système
En anglais - c'est trop longtemps que je parle francais...
The code you mentioned sounds like an Ink System Failure code. My C6180 had the 0xc19a0035 Ink System Failure code, eventually the printer would power on and off every 15-20 seconds - continuously. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other HP printers.
SOURCE: Bonsoir, Sans arrêt, une fenêtre apparaît.
recommandé d'exécuter malwarebytes ou AdAware. peut-être un virus?
SOURCE: comment faire pour changer la
English to French translationJ'ai trouv? cette instruction ailleurs sur ce site (merci ? pctuneup191):
PROC?DURES POUR CHANGER LA COMBINAISON DE S?RIE CIPHER SIMPLEX 1000 SERRURES
1.) ASSURER LA PORTE EST OUVERTE.
2.) Introduire la cl? CONTROL DF-59 ? l'Assembl?e de changement de combinaison (SUR LE DOS DE LA
PORTE) et d?visser le cylindre en tournant le CLE.
3.) Consid?rer que l'Assembl?e PLUG changer compl?tement hors de la porte.
4.) Tournez le bouton PORTE EN DEHORS dans le sens horaire jusqu'? ce qu'il s'arr?te, puis la rel?cher.
5.) PRESSE DANS L'actuelle combinaison FERMEMENT.
6.) Ins?rer la cl? de b?tons dans les roues MANCHON changement de combinaison. IL YA INSERT sur les neuf
Heures.
7.) Tourner la cl? CLE DOUCEMENT montre jusqu'? ce qu'il s'arr?te ? la position 12 heures. NOTE
Les encoches de combos LA MANCHE CHANGEMENT QUE le manchon est d?plac?.
8.) Tourner la cl? CLE ANTIHORAIRE RETOUR ? la position neuf heures jusqu'? ce qu'il s'arr?te.
Retirer la cl? CLE.
9.) Tournez le BOUTON DE PORTE EN DEHORS (tout le chemin, jusqu'? ce qu'il s'arr?te), puis rel?chez.
10.) Taper la combinaison en appuyant sur les boutons. Utilisez au moins trois chiffres et un
maximale de cinq ans.
11.) Tournez le bouton PORTE MONTRE UNE FOIS, tout le chemin, jusqu'? ce qu'il s'arr?te. HOLD dans cette position et
VERIFIER SI LE p?ne est r?tract?.
12.) COMMUNIQU? la poign?e de porte.
13.) Tournez le bouton PORTE DROITE One More Time ? la position STOP. ? ce stade, LE LOQUET
Doit pas se r?tracter sauf si vous utilisez la nouvelle combinaison.
14.) REINSERT la bouteille dans le dos de la porte en la vissant dans une montre avec la DF-59
KEY CONTROL (NE PAS TROP!)
Retirer la cl?.
Un Df-59 cl?s peuvent ?tre achet?es sur ce site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
La cl? de serrage (SMPBC201278 Simplex: SpannerWrench 9,00 $) vis?s peuvent ?tre achet?s sur ce site:
http://www.ckilock.com/Mpage18.asp
Vous trouverez un lien pour t?l?charger le manuel de votre mod?le sur cette page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Ce sont des fichiers PDF, n?cessitant Adobe Reader pour ouvrir. Il ya un lien sur la m?me page pour t?l?charger Adobe Reader.
Service ? la client?le peut ?tre contact? directement depuis ce lien:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Assistance technique ? partir de ce lien:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Bonne chance!
SOURCE: BONSOIR J AI UNE ONE FOR
Essayez: Thomson 0287 0399 0109 0501 0333 0471 0335 0196 0198 0237 0343 0037 0490 0568 0625
Si la t?l?commande est plus vieux que la t?l?vision, alors vous devrez peut-?tre une t?l?commande plus r?cente.
(Remote codes are usually limited to those for devices released more than 6 months before the remote was programmed.)
