Pacearrow 35 ft leaking hot water
SOURCE: Whirlpool® 4.6 Cu. Ft. Cabrio® HE Washer leaking water
coins may have breached the outer tub. expensive way to learn to remove loose objects fro clothes before washing them
SOURCE: water leaking from bottom. what's up?
http://www.saecoparts.com/SaecoItaliaEspresso.html Check the diagram. Could be one of the internal plastic hoses. One of these caused the leak on mine.
SOURCE: hot water heater is leaking and making noise
Hit the disconnect and call a plumber. Sounds like your heating element or elements have gone bad and need to be replaced. also shut off the water. This is repairable, but it is HIGHLY recommened to have someone with expeirence in this kinda of problem fix it since you are messing with water and electricity. The repair should be no more then 200 dollars
SOURCE: driver side floor water leak
Well, you are on the right path; the rubber seal around the windshield could indeed be deteriorating...what may be happening is the water is coming through the cowling and pooling up on the seal there...as the water sits, the seal deteriorates and eventually you will see water like you are now.
My recommendation to you is to take your Edge to a shop and ask them to look for a leak at the bottom seal of the windshield.
Testimonial: "Help was much appreciated."
stopped up drain,tear in gasket,not going into defrost soon enough
