I had a Kenmore 158 that was probably a bit newer than yours (late 60's), so I would guess probably mid 60's. Good little machine. Make sure to clean and oil the internal moving parts regularly with good quality sewing machine oil or liquid Tri-Flow Synthetic Lube to keep it running smoothly. Old oil will dry out over time and cause the parts to seize.
Wheel on right side that controls the needle up and down is very tight...
Manufactured in the mid 60s perhaps in Japan by Maruzen.
Kenmore Sewing Machine model 158 905
SOURCE: Availability of needles
Practically every machine made in the last 50 years uses a 15x1 needle also known as 130/705 universal fit.
sewman7
SOURCE: light goes out when I start to sew
This may or may not help.. first UNPLUG it..then unscrew the light bulb and look at the base of the bulb socket.. you should see a tang there ( small tab) that makes contact with the bulb.. sometimes that gets compressed to a point that it won't make electrical contact with the bulb or intermittent contact and the bulb flickers.. You may also have a loose wire on the socket terminals too.. Depending on your electrical skil level, you may or may not want to look into repairing that yourself.. Hope this helps..
SOURCE: old kenmore runs at choppy when trying to sew
Lubricate the machine. All metal against metal places. This should allow the machine to run smoother. This is an older machine and may need to be run full speed for a while to let it break free.
SOURCE: hello I have an old
Hi. Unfortunately, sewing machines were manufactured by the millions and those from 50 years ago are still going strong and readily available. The value of any sewing machine is determined by how much someone is willing to pay for it. There are some older machines that collectors will pay good money for, if the machine is in excellent shape and has all the attachments. To get an idea of what people are willing to pay for your machine, check the listings in Ebay. There is a vintage kenmore group on yahoo groups that you can check also.
Hope this helps,
Robbie
SOURCE: kenmore sewing machine won't sew vinyl
There is several things you should use when stitching vinyl, treat it the same as leather. The main issue usually is getting the feed dogs to grip and move it through; this is why there are commercial grade machines specifically for leather hides and fur etc, it is tricky to stitch.
To stitch on a domestic machine, you need a leather needle with a spear tip to cut the leather so it doesn't split. Also, if you can get one, use a roller foot to roll over the fabric, or a teflon foot if you can't find a roller one. Also, use paper clips rather than pins to hold raw edges together (remove as they approach the foot and needle). You may also need to bash seams open after stitching (rubber mallet) and glue down the raw edges, this is how leather hides are stitched professionally. If you have to join more than 2 layers ie crossing seams, you'll probably need a Jeans-a-ma-jig device to help with feeding through the thickness and still getting feed. Like this http://www.punchwithjudy.com.au/shop/jean-a-ma-jig.html
You don't say what it is actually doing, ie stitches not catching, or the feed dogs not moving it through?
But if it is an entry level machine, it may not have sufficient engine power to pierce the vinyl, especially if the textile is thick. Also, don't try to use a heavier thread than normal weight, if you want the stitching to look heavier, then just run two reels of thread through all the thread guides, tension and the needle eye together. Something like buttonhole twist will be too heavy for the bobbin tension and top tension to handle.
Hope that this helps you with your project.
