Question about Sony Cell Phones
What is a smartchip for a sony ericsson. what does this smart chip even look like?
I cant figure out what a smart chip is
  • Sony Master
  • 10,628 Answers
6ya staff
SOURCE:
keithd2704
Keith Deininger
  • 56 Answers
SOURCE: sony ericsson smartchip
I've had the same problem occur once or twice. Seems when the cellular provider makes a system switch from one tower to another system (carrier) the SIM chip can sometimes become temporarily deactivated.
To solve this issue complete the following steps:
1. Shut your phone down
2. Remove your battery and leave it out of the phone for a few minutes
3. Remove you SIM card and wait for a count of 10sec
4. Reinstall the SIM and battery
5. Power the unit on
6. Perform an Initial System Configuration/Setup
7. When the system prompts you to copy the phone list information, select YES
8. Check your phone status. It should now be back to normal.
If following these simple steps does NOT bring your phone back to normal, there may be a problem with either your cellular account (account suspended) or there has been failure of the local cellular network you are trying to connect to. To verify this you will need to either have a second phone with the same carrier to verify connection and/or SIM functionality. If this is not possible, contact your service provider to report a service outage.
Keith
Posted on Oct 15, 2008
Anonymous
  • 6 Answers
SOURCE: insert correct smart chip
your phone is locked tell me operator of the phone and i will genrate unlock code but not free if interested contact me on buy@unlockhtc.org
Posted on Jan 30, 2009
Anonymous
  • 214 Answers
SOURCE: Inactive Smart Chip
Unfortunately if it's a bad smart chip I'm afraid you will have to buy another phone. If you've had it several years you really got your moneys worth. Good luck, sure wish I had better news for you.
Here's the AT&T forum about this..
http://forums.wireless.att.com/cng/board/message?board.id=sonyericsson&message.id=29293
Posted on Jan 31, 2009
Anonymous
  • 52 Answers
You cannot reactivate a smartchip aka sim card...once it's deactivated for security purposes they are not reactivated. You will need to get a new smartchip
Posted on Feb 11, 2009
nicky1807
Nikhilesh Kumar Ch
  • 17 Answers
SOURCE: after resetting and downloading software for my
This means your phone is locked to some network you have previously used( Means u can't use other SIM Card unless ur phone is UNLOCKED) n r u having any contract with any network???
- Nicky
Posted on Jul 13, 2009
I cant find a solution for my HP Deskjet D2560 Inkjet because its not printing since we change the cartridge how can i solve for it? reagrds junah,
Make sure you are using HP ink cartridges or you could effect you print head. The ink cartridges have smart chips in the. Make sure your firmware is up to date. Try another ink cartridge too, only after you update your firmware. You can get updates off HP website. http://welcome.hp.com/country/us/en/support.html outdated firmware can kill the smart chip in your ink cartridge. Installing another ink cartrige before updating your firmware will kill the smart chip in that ink cartridge the same. Try taking your ink cartridge out and wait a minute and reinstall it as well. You must update your firmware using the USB cable only not through wireless. Let me know if this helps. I had this same thing happen to me. I had to simply update my firmware. Good luck.
Mar 07, 2011 | Audio Players & Recorders
ASKING TO INSERT SMART CHIP
just break the screen so u cant see that it says that
Jul 13, 2010 | LG Vu CU920 Cellular Phone
I got my lg View from a friend and when i put a sim card in it says Insert Smartchip
Cut a small piece of cardboard or credit card plastic similar in shape to -- but just a bit smaller than -- the smart chip. Place the piece on top of the smart chip. Simultaneously slide both the smart chip and the piece of cardboard/plastic into the smart chip slot. Make certain you are inserting the smart chip with the proper end inserted first and with the contacts uncovered by the extra piece (On the LG Vu, the smart chip contacts will face down and the missing corner will be showing on the outside of the slot when the card is inserted properly.). If that doesn't do the trick -- see your cell phone provider and/or get a new phone.
May 20, 2010 | Cell Phones
Insert smartchip
You are placing the smart chip on top of the smart chip holder. It's a little metal square where the smart chip should go. Lift up the metal square and place the smart chip underneath. I had to go to my local AT&T dealer to figure this out.
Jul 11, 2009 | LG Shine CU720 Cellular Phone
Nokia 2610 'Smart Chip Registration Failed'
off the phone ........ change the setting
Jun 13, 2009 | Nokia 2610 Cellular Phone
Says insert smart chip
It is possible to put the sim card in backwards.  My daughter did and when we turned it around I no longer got the "smart chip" error message.
May 27, 2009 | LG Vu CU920 Cellular Phone
"insert smart chip" eror message - smart chip is in but nothing
Hi there!
The first thing to try is cleaning the contacts for the smart chip, on the phone and the chip itself. Use a little rubbing alcohol on cotton buds and be careful you don't bend the contacts in the phone. If that doesn't remedy the problem, get your service provider to give you a new chip. They should be willing to give you one for free. If that doesn't fix it, then it is probably a phone problem. You may go to your service provider or any nearest mobile phone repair shop to have it fixed. You may also have the phone replaced if your budget allows it.
Happy holidays!
Dec 22, 2008 | Sony Ericsson W300 Cellular Phone
Samsung CLP-500 problem
Resistors? You mean the smart chips?
Here's something I found over the last few years of dealing with these newer laser printers.
Say for example you had a 13,000 page factory toner, you replace it with a 20,000 page aftermarket refill, but you trade off the chip. There are small case triggers that read the toner size (I still haven't figured if it's internal or external) The chip is programmed for a specific cartridge size. The carts don't match, the chips won't work.
Also, certain printers will recall chips that have been used, and won't let you reapeat chips until you have gone a certain number (like it has to have 4 or 5 different chips before you can reuse the first chip).
So options to get around it.
I found in the Dell printers, if you go through the menus, there is a setting that allows you to bypass using factory cartridges, I don't know if Samsung has the same menu settings, but it's worth digging through the layers.
2) Put the chip that came with it back in, and see it it will work.
3) Break down and buy a factory cartridge. I know this is the least attractive option, but it will determine if it is a read sensor, a firmware/software error, or something else.
The whole smart chip imbedding happened about 7 years ago as a settlement on a lawsuit.
Oct 28, 2008 | Samsung CLP-510 Laser Printer
Smart chip
u need to unlocj that phone again.
Sep 21, 2008 | Nokia 6300 Cellular Phone
Smart chip
You can try 0000, 1234 or the last four digits of your cell phone number. If that doesn't work to unlock it then you need a new smart chip.
May 27, 2008 | LG CG225 Cellular Phone
Cell Phones Logo
141 people viewed this question
Top Sony Cell Phones Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
