Before I interview this person, I will do some background research on the prospect and ensure that I have appropriate questions to ask. During the interview, I would make sure that I answer the prospect's questions and maintain eye contact with them. I would ask them all appropriate questions and give them an outlook of the job description. After the interview, I would reach out to their references and discuss their skills with other employees before making a final decision.
You need to seriously prepare for the interview! You can re-read the main questions that are asked by future engineers during the interview. You need to know these answers, because they all relate to your future profession. Basic Electrical Engineering Interview Questions
SOURCE: Locked file
The folder lock can oly be solved by chosing the option "format" in the sub-menu. But please copy the *.dss - files still resting at your card at your harddisk first.
When the recorder finishes the format procedure, all folders will be unlocked again.
The "Read-Only-Failure" will occur again at recorders with differend user profiles, when you put the switched-off recorder into the docking station first and switch the power button to "on". So avoid this constellation!
SOURCE: very bad recording
Be sure you are in the SP record mode and use the dictate conferance setting depending on your environment.
SOURCE: excel sheet help
You're covering a lot of ground there, but you should be able to use sorting and group selection, then cut and paste from your other programs, as well as keyboard shortcuts to save some time. There may even be some addins that will help you to organize the reports...but nothing can save you from data entry. There's definitely a steep learning curve involved...
It may be helpful for you to organize the logic and Hierarchy of the spreadsheet by hand on paper before you attempt to set it up on your system.
Google Excel tips and you'll find a plethora of info online to help you set it up right...(here's one) (or two)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: in an interview if an
your answer should highlight your main strengths, & how the employer would benefit from them in the job. For example, if you have strong organizational skills, your answer should point out that, giving an example what positive impact this could have on the job. And so on.
SOURCE: why should i hire you
This question is particularly asked to see the confidence level of the candidate. So, while answering this question, you should talk about your industrial experience, technical skills, education, ability to understand the various responsibilities that you might have taken up in the past.
