Watches Logo
Kacey Penaflor Posted on Feb 21, 2018
How to set the right time on casio watch - Casio Watches
5 Related Answers
A
Anonymous
  • Posted on Feb 11, 2008
SOURCE: How do I set the 12 or 24 hrs setting on my Casio DW 9052 casio?
when you are setting the time just hit the (g) or light button and it will switch it to 2400 time.
Anonymous
  • Posted on Mar 12, 2008
SOURCE: need too set time on my g shock casio watch
Press Adjust and hold until blinking city appears.
Press Mode until DST appears flashing.
Press Recieve until mode that you want appears ON OFF AUTO
Press Adjust until not blinking city code.
A
Anonymous
  • Posted on Jul 20, 2008
SOURCE: Casio AQ-161 combi watch - unable to set the digital time
The Casio web site has all manula on line. The model no is 3352
Good luck
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 31, 2009
SOURCE: i cant set analogue time on casio hd wrist
Follow this link:
http://world.casio.com/wat/download/en/manual/
Rate, please.
Anonymous
  • Posted on May 07, 2009
SOURCE: can't set the time on my casio wrist watch
Press button A (top left) and hold for two seconds. The watch should then receive a time signal - you shouldn't have to set the time on it at all.
4helpful
2answers
Need to set time on casio illuminator AW-81
Hi,you need to look at the user manual..
just in case ,if you need soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
I HAVE A CASIO G SHOCK WATCH AND I MISPLACE THE OWNERS MANUAL AND CANNOT SET THE RIGHT TIME SINCE DST.
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Mar 17, 2011 • Watches
21helpful
2answers
How to set clock time on casio aw- 81 time
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
A - upper left button
B - upper right button
C - down left button
D - down right button
In the Timekeeping mode, Precc C six times to enter to Hand Mode
Hold A until the current digital time start
Hold D to advance the analog time
If you like advance the analog time a long away, press D + B the same time. Press A to exit the setting screen.
To return to the Timekeeping mode press C
3helpful
How do i set the hands to the time on a a casio g
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
5helpful
Set the hands on a g shock to the right digital time
Select "support" and the "manuals", watches;
Accept terms
12helpful
Analog time setting
On the assumption that my Casio watch works the same as yours, press the mode button (lower left), until "HS"appears, then use the buttons on the right to advance or ****** the hands.
If this does not do the trick, then go to the Casio web site "casio.com" select "support"then "manuals"; accept terms and conditions and the select "watch manual archive"
Insert the required number off the back of your watch and download the instructions.
60helpful
3answers
Cannot set the analog time on the Casio 2747.
In timekeeping mode press bottom left button 6x to enter setting mode.
Then hold down top left button until digital time flashes, which indicates your in analog time setting mode. press bottom right button to set the time.
If you hold down bottom right, it will set time at a faster speed.
Hope this helps
8helpful
2answers
I cant set analogue time on casio hd wrist
Follow this link:
Rate, please.
Casio g-shock mtg-900 gets ERR when trying to set atomic time
Did you go to Casio and download the manual? I just did after my battery change and I hoping it updates tonight at 2,3, or 5am with my watch in the window.
740helpful
9answers
Setting time on casio illuminator watch
Here is how you do it:
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode.
Press "C" to return to timekeeping mode.
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
