SOURCE: wireless card
Let me guess...it comes up as an unknown pcmcia controller.
I have 4 pcmcia cardbus cards and the only one that my armada M700 recognizes is a twinmos B. All others come up as unknown pcmcia controller.
SOURCE: sony ericsson gc83 to unlock
Cingular usually has a standard pin# of 0000. If this does n't work contact cingular they might not be compatible with each other. I have been a cingular customer for over 10 years, and have found majority of what they have works within there own equipment. trying to use the pc card with t-mobile, although it is a great Idea, and makes sense, I believe it is a compatability issue. makes some calls, and if you dont get the answer you like from cingular, call and talk to tech support from both sides t-mobile, and cingular.
SOURCE: do i need a wireless
I have looked up the general specs of your computer and there is no wireless card included.
I hope this helps
SOURCE: Windows XP Pro desktop with malfunctioning Gigabyte Wireless LAN PC card
http://www.ebay.com.au/itm/Tiny-Micro-Mini-Wireless-N-G-802-11n-WiFi-LAN-WLAN-USB-Network-Dongle-Adapter-/290729758011?pt=AU_Components&hash=item43b0d80d3b
http://www.ebay.com.au/itm/300Mbps-USB-Wireless-N-WiFi-Adapter-Dongle-802-11-bgn-High-Gain-Genuine-W4-/190666378926?pt=AU_Components&hash=item2c649a0eae
you might get one of these
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
http://www.paypal.com/
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
SOURCE: Low wireless signal on HP slimline Pavillian s3000y desk top pc with Lite-on USB wireless LAN card
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default. Change to anotherchannel.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedropouts and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
Turn the laptop over and remove the battery.
Remove the screws that are used to secure the memory/wireless LAN minicard cover with a Phillips-head screwdriver. Lift the edge of the cover to remove it.
Disconnect the antenna cables from the wireless LAN minicard with the needle-nosed pliers.
Locate the screws that are used to secure the wireless LAN minicard to the motherboard and remove them with the Phillips-head screwdriver.
Pull the wireless LAN minicard out by grabbing the card by the edges.
Reinsert the wireless LAN minicard and push down on the card to set it in place.
Tighten the screws to secure the card to the motherboard.
Replace the antenna cables with the needle-nosed pliers.
Replace the memory/wireless LAN minicard cover and secure it with the screws.
Replace the battery and then turn on the laptop. Windows Vista will load and reinstall the drivers for the ISATAP adapter.
hope this helps
