Like above budgail said, its a tv remote issue. If you can get the original remote and press exit, your good. But if it still hasn't gone away, looks like an update for the tv got screwed up.
I would suggest call LG and see if they can help you from there. Here is the number to call
1 (888) 542-2623
Testimonial: "Is it fixable without the original remote? If yes- how?"
SOURCE: MY LG 20LS7D TV WILL
You have lost your original remote and got into this by pressing info select and the option 7 UART Download. Happened to my 95 year old aunt in assisted living. You will need the original remote and simply hit (EXIT) or another LG branded remote that has the (ROUND RETURN BUTTON) on the left. Once you accidently get in to this, I have not found a universal Zenith remote that can get you out even though Channel up/down and basic funtions work.Bud retired Bud's TV Service.
An RS-232 null modem serial cable is required for this procedure.
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
