If its not an bad soldering or an passive component , beware almost all brands wenn ordering an electric part for a charger its almost always more expensive then a complete (new charger ) the latest years there are more and more remplacement options to the customer , if there are defect components that are not made for ordering on marketing technical reasons and safety and more reasons. mosnfets (passive component almost sometimes fuse resistors but smd components to repair is not meaningfull . when termical defects are hidden.
SOURCE: Fuji Fine Pix Z5 battery won't charge
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch
the positive (+)end of the 9v battery to the positive (+) end of the
camera battery.Leave them touching for a few seconds (10 seconds should
be more thansufficient). Seems these lithium-ion batteries are subject
to a'digital memory.' Subjecting it to a volt surge almost three
timeshigher seems to clear it.
http://www.batteryuniversity.com/parttwo-34.htm
In short, it works like a charm.
SOURCE: I have 28v milwaukee tool kit and the batteries,
you can try and unplug the charger for a couple minutes and then retry. I have a LiIon at work and sometimes it does it also, if not then the batterys would probably be bad, I would contact Milwaukeetool.com and see about warranty replacement for these. They have a good warranty on the newer products.
SOURCE: New Hitachi 3.6v HXP EBM315 Li-ion battery won't take a charge
when i turn on my drill amoked comes out hohw can i fixed it????
