SOURCE: mice ate wiring
Try to trace all wires and see if the metal part is still intact. Do not turn it on or allow electricity to pass yet! If wire metal intact, get some good quality black electrical tape and carefully tape all the exposed metal. When done, test system.
To prevent problem, use moth balls, fabric softener sheets, or pine sol soaked on cloths to deter mice & rats. If possible, use old- fashion mouse or rat traps with peanut butter to kill intruders to your boat. If you agressively eliminate them, the problem will be solved, but you may have to periodically repeat the trap use.
SOURCE: need Wiring Schematic/Diagram for 89 Astro GT16 boat
In all honesty, its probably impossible to get the original wiring diagram. Also, I would be willing to bet that there has been alot of re-wiring and changes made to the wiring and electrical system of the boat. If you describe exactly what your trying to do, install fix or re-wire I may be able to better assist
SOURCE: I have a 90 Horse power Mercury outboard Boat
Sounds like the starter. Check if you have power at the solenoid from the battery with just the power on (key turned on, power switch on.) thats good-- you have power-- if not you have a wiring problem from your battery or main switch.
Otherwise you have a starter problem probably.
SOURCE: I need a wiring diagram for a 1990 heritage 1600
wiring diagram for a 1990 heritage 1600 starcraft boat type this in and do a web search. Is the wiring for the boat are for the motor? Jim Retired OMC Mech
